Sub sounds like a God damn Tweeter!
binge
, Jun 17 2005 12:20 AM
11 replies to this topic
Posted 17 June 2005 - 12:20 AM
Ok, installed a Sub and an amp the other day. only yesterday did I noice (after opening the boot while music was on) that my sub is acting like a normal Speaker...
Now I have a "Sub out" on my Head unit. Ive got it set on "Full" on the amp as the oter setting is for No bass at all.
How do I go about getting it to act as a sub and not a normal speaker?
And CHEAP! :cheese:
<|Ben|>
And CHEAP! :cheese:
<|Ben|>
Posted 17 June 2005 - 06:25 AM
get a crossover! mine does this aswel and its because the amp doesnt have a low pass filter. try maplins, i think they do em cheap
Posted 17 June 2005 - 10:37 AM
A problem one of my mates had was that he had the LOUD setting off on his HU. so it mite be a case of finding the loud button n itll all be fine
Posted 17 June 2005 - 12:09 PM
Sub output on head unit? What head unit do you have? This usually implies a filter built in to this exit, just a matter of switching it on on the head unit.
Also your amp really should have a filter, unless it utter C**p:\ I can't think of any amps to be honest (not even the cheapest brand name ones I know) that don't have even a simple filter system for a sub channel.
Some more details of your equipment would help!
Posted 17 June 2005 - 01:27 PM
sounds like a low pass/hi pass issue.
check your deck too, as i know that on my alpine I have subwoofer volume and db control.
keep us updated. :cool:
Posted 17 June 2005 - 01:33 PM
Ok, I have a AWIA CDC-R304
• dark silver facia (detachable)
• blue display/key illumination
• mos-fet 52w x 4 max output power
• dssa
• h-bass
• dimmer control
• drive-s
• source level adjuster
• 7 preset / 3 band eq
• front aux input jack
• pre / sub changeable line-out
• rds
My amp is a cheap C**p Sound Storm 400watt thing I got in amearica. it has a High Pass filter setting, and a "Full" setting.
I took my bedroom speakers apart AGES ago and it has a Crossover for the different components in the speaker box. Ive used put the crossover from that in my system and it hasnt made a difference at all...
Any ideas?
<|Ben|>
• dssa
• h-bass
• dimmer control
• drive-s
• rds
Any ideas?
<|Ben|>
Posted 17 June 2005 - 02:41 PM
Okay on your head unit you'll have to change it so that the output (line output) is SUB, not PRE-OUT. If SUB it should stick some sort of filter on it. If you select pre-out it will play full range of frequencies.
You sure your amp has a high-pass filter? What's the frequency range of the filter?
Posted 17 June 2005 - 03:13 PM
sorry to hi-jack the thread but i have an alpine 9828rb headunit and i dont seem to have this filter on either. my amp is an alipine but is ancient so hasnt got a filter
Posted 17 June 2005 - 06:21 PM
rite as been asked "You sure your amp has a high-pass filter? What's the frequency range of the filter?" If this filter drops low enough u can use this as a subsonic filter meaning u can have it set so the sub doesn't try and drop lower than it /the enclosure was designed. Then once u switch the sub pre out on u should either have a fixed lp filter or 1 u can adjust, then all should be good.
Posted 18 June 2005 - 12:30 AM
Highly doubt it will act as a subsonic, and even if it does won't make much of a difference to a budget set up.
If however the guy got it confused and the amp has a low pass filter it's all much easier. Just need details of head unit pre outs and confirmation of amp filters!
Posted 18 June 2005 - 12:33 AM
I have the Pre out set to "SUB"
My amp has a volume control and a Switch for each channel...
Now The switch is on the "Bassyest" setting at the moment. its got "FULL" and "HI PASS" Written on the switch...
Its really gay... A totally naff amp I bought in America!
<|Ben|>
<|Ben|>
Posted 18 June 2005 - 12:12 PM
umm... that IS gay
Dunno if its possible, but... get another amp? Will probly sound better too!
