It took a long time to find a suitable needle to suit the car, so a needle needed to be modified to make it richer top end. He modified a BBW needle to suit. The spec of the engine is :
Morspeed 1293 Engine
Balanced internals
Kent 276 cam
Morspeed stage 4 head with 36inlets/31 exhausts
Double valve springs
Morspeed rebuilt gearbox with centre oil pickup
Duplex timing gears
Alloy inlet manifold
HIF44 carb with modified BBW needle
Custom ram pipe (no air filter)
LCB manifold
Play Mini single box system
I think that is everything but i may of forgotten some things.
The end results were 88.8 hp at the flywheel and 82.2 lbft of torque at the flywheel. Really happy with the figures!!
