2 X Twinblade Metal Fan?
10 replies to this topic
#1 Waffs1984
Waffs1984
  • 437 posts
Posted 04 August 2008 - 08:39 AM
Hi guys,
My mini seems to run fairly 'hot'. I have a TIM capiliary water temp gauge fitted and the car runs at about 85deg, but after about 15mins driving it will hover around 90-95 (i know 'modern' cars run at 90 deg) and sometimes even up to 98deg!
Now i don't really think this is a problem as such but i'd be happier if i could cool the engine a bit more, would fitting two of the metal fans crossed over (to make a 4-blade) which i have read about prehaps give me greater cooling?
http://www.minispare....aspx?pid=38630
Cheers,
Matt.
#2 Wil_h
Wil_h
  • 3,244 posts
Posted 04 August 2008 - 10:25 AM
Probably not, you'd be better getting a bigger/better rad
#3 mini_kel
mini_kel
  • 2,851 posts
  • Local Club: EMC/No pub mini club
Posted 04 August 2008 - 10:36 AM
What fan is in it now? and have u changed the thermostat??
#4 62S
62S
  • 1,243 posts
  • Local Club: You must be joking!
Posted 04 August 2008 - 11:29 AM
If you do go down the 2A 997 route you also should fit the stiffener (part no 2A 803) which Mini Spares don't seem to list
#5 Waffs1984
Waffs1984
  • 437 posts
Posted 04 August 2008 - 12:00 PM
I have the standard plastic 11 blade plastic fan in at the moment, although i have just seen the 6 blade metal fan on minispares that it says is for use in "hot climates" - maybe this is the way to go?
Yes thermostat, head gasket and water pump all changed by myself straight after buying the car, i'm confident there is no problem there. I *think* i may have a slight issue with the heater hose/bottom hose connection, there is some evidence of a leakage there showing up as white residue on the hose (like the limescaly kak you get around leaky thermostat housings). I will be upgrading to the silicone hoses eventually though!
Cheers,
Matt.
#6 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 04 August 2008 - 12:17 PM
Cheers,
Matt.
Did you put the fan on the right way round when you changed the waterpump??
#7 Waffs1984
Waffs1984
  • 437 posts
Posted 04 August 2008 - 01:07 PM
Cheers,
Matt.
Yes, i checked and double checked as i heard that this was a common error. The fan actually had an inscription in the plastic stating "Engine Side" ;-)
Any other ideas guys, could it be due to a small leak somewhere that means the system is not fully sealed? I have pressure though when removing the rad cap 'hot' and she doesnt lose massive amounts of water, about a cupfull on a 400miles round trip. Maybe there is a slight leak (like the one i *think* i have - mentioned earlier) that is causing small levels of water loss but not enought to reduce pressure in the system?
Help so far greatly appreciated though guys, keep it coming! :P
Matt.
Edited by Waffs1984, 04 August 2008 - 01:08 PM.
#8 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 04 August 2008 - 01:09 PM
Probably down to a partially clogged rad and water system?
Have you tryed back flushing the rad etc>?
#9 Waffs1984
Waffs1984
  • 437 posts
Posted 04 August 2008 - 02:20 PM
I haven't flushed it with a hosepipe, but i did fill up, run it and then empty it all out again and repeated this about 3 or 4 times after i first did the HG work. I forgot to mention that the rad is a brand new standard 4-core rad from minispares. On this topic, i have a feeling my heater valve is siezed, would this casue water to not circulate properly around the system?
Matt.
#10 T.Harper
T.Harper
  • 714 posts
Posted 04 August 2008 - 04:03 PM
wouldn't trust myself with a metal fan. Bye bye fingers!
#11 Waffs1984
Waffs1984
  • 437 posts
Posted 04 August 2008 - 04:13 PM
LOL!
