Dashpot Oil
Posted 17 June 2005 - 09:05 PM
Question is this
Will it matter if I mix oil types or should I stick to oil as detailed in owners manual
Posted 17 June 2005 - 09:29 PM
Posted 18 June 2005 - 01:29 AM
I have found by experimenting (on a Chevette) that if you use brake fluid, you get a quicker throttle response than with engine oil.
Just for a bit of fun, I once took out all the fluid from the dashpot and tried that, (You must make sure that the engine is warm as it won't start otherwise), the throttle response that I got was almost immediate.
Who knows what damage is occuring, but it's fun anyway!
Have fun,
B1ondini.
Posted 18 June 2005 - 01:52 AM
Posted 18 June 2005 - 05:38 AM
I generally use 3in1 as it comes in a handy tin :cheese:, you can get genuine SU carb oil, in a couple of grades, and engine oil is ok, ( however I find it a little too thick for winter driving )
Auto fluid is just another grade of oil, but if you don't have an automatic (not mini), is rather expensive to buy a 1 litre tub for only one purpose.
Posted 18 June 2005 - 12:30 PM
Regarding brake fluid, it's not a good choice. I don't know about the corrosive comment, but it is hygroscopic and will cause the steel bits of the dashpot to rust if you don't replace the fluid often... just like bleeding/replacing your brake & clutch fluid every couple of years.
Posted 18 June 2005 - 01:17 PM
Posted 18 June 2005 - 08:44 PM
Posted 28 January 2007 - 11:21 AM
i thoght generally if you have an engine that revves p quicker then a thinner oil should be used to alow the increment of fuel and air to be the same
the guy who i use to do my mini tuning and stuff recommends brake fluid. it has to be topped up every couple of weeks anyway so corroding the carb isnt a problem as its not in there long enough! even 3 in 1 oin is too thick. albeit i am running twin strombergs not su's!
Posted 28 January 2007 - 01:51 PM
10w40 - 20w50 (20w50 might be a too thick but ultimatlely it's up to you to decide how you like your car to drive) is a good starting point, The carbs were designed to run on the same oil as the engine does.. if it's a bit sluggish, thin the oil down with some 3-1.
Personally I like a nice smooth throttle response with no piston bouncing, 10w40 all the way. Brake fluid... get lost!
Edited by Retro_10s, 28 January 2007 - 01:52 PM.
Posted 28 January 2007 - 02:12 PM
Posted 28 January 2007 - 02:20 PM
holy thread revival batman.
Lol my thoughts exactly robin, f251dgc must've been trawling thorugh the forum
Posted 13 February 2007 - 02:03 PM
What are the discernible symptoms of 'piston bouncing'..?
Posted 13 February 2007 - 04:17 PM
Posted 13 February 2007 - 04:52 PM
