Hey people,
Could you point me to the correct radiator cap for my 1996 spi min ?
http://www.minisport...fo_SPD0006.html
is that the correct one ??? As i seen some advertisment saying the black one if the one i need!
Just a bit confused
Ming
Radiator Cap ?
ycming
, Aug 06 2008 11:38 PM
5 replies to this topic
Posted 06 August 2008 - 11:38 PM
Posted 07 August 2008 - 10:56 AM
Looks ok to me, assuming you've definately got a '96 SPi with the side mounted rad. The black ones you may have heard about could be the black plastic ones for the MPi's (which have a front mounted rad with an expansion / header tank) which are different in that they are screw threaded rather than bayonet fitting, and don't have the lugs on each side.
Posted 09 August 2008 - 12:28 AM
That's the thing, the current one, is the black one type. and looks like the one in the link i posted...
Ming
Ming
Posted 09 August 2008 - 12:51 PM
Is this a front mount or side mount rad. Its an odd ball if its an SPi with a front mount rad
Posted 09 August 2008 - 01:51 PM
is side mounted SPI.
Ming
Ming
Posted 09 August 2008 - 06:58 PM
That rad cap should be fine then
