After a few attempts at cranking the engine on the key, the plugs weren't fouled up with fuel so we decided to swap the carb for the one off my old 998 to see if the carb was at fault. Tried cranking it again and it sounded a bit more promising, took a plug out and the smell of fuel was there this time. Play was called off due to the battery being dead, so its on charge now and I'm going to give it another go later.
In the meantime I've got the HIF44 on the floor in the shed, I've no idea what I'm doing so have only taken it apart a little bit.
The needle is very loose in the piston (
