Sub Mounting Depths
10 replies to this topic
#1 jwb_moto
jwb_moto
  • 1,387 posts
  • Local Club: PMOC
Posted 08 August 2008 - 09:56 PM
if a sub has a mounting depth of 137mm whats the minimum gap i should have behind te magnet of the sub?
#2 Ruckus
Ruckus
    Ice Ice Baby!!!
  • 2,071 posts
  • Local Club: SMOC
Posted 08 August 2008 - 11:14 PM
Really depends on the sub, but plan for no less than the diameter of the pole vent/piece.
Is the sub vented ? most are but its worth checking..
Edited by Ruckus, 08 August 2008 - 11:15 PM.
#3 jwb_moto
jwb_moto
  • 1,387 posts
  • Local Club: PMOC
Posted 09 August 2008 - 09:33 AM
the sub im thinking of buying is
Linky
could you advise for this sub
#4 sixtyeight
sixtyeight
  • 630 posts
  • Local Club: forums.minidriver.com.au
Posted 09 August 2008 - 11:04 AM
minimum space behind magnet = mounting depth - subwoofer depth
might want to ask the ebayer how deep the speakers are.
but basically you need at lest 137mm.
Edited by sixtyeight, 09 August 2008 - 11:06 AM.
#5 jwb_moto
jwb_moto
  • 1,387 posts
  • Local Club: PMOC
Posted 09 August 2008 - 02:13 PM
do i need extra space behind the lowest part of the sub (i.e. magnet) when its sitting in the box? or is it just a case of as long as it doesnt touch the back of the box and the volume is right?
#6 Ruckus
Ruckus
    Ice Ice Baby!!!
  • 2,071 posts
  • Local Club: SMOC
Posted 09 August 2008 - 06:46 PM
?? guys i really answered this in my first post..
;D look email the seller ask:
1: Is the sub vented
if no the just make sure the base of the magnet does not touch the back of the enclosure
if yes, then ask
2: What is the diameter of the pole piece
but if you had to guess i would leave 1.5" or 1" min.
Where are you planning to install this sub by the way ?
Edited by Ruckus, 09 August 2008 - 07:37 PM.
#7 Ruckus
Ruckus
    Ice Ice Baby!!!
  • 2,071 posts
  • Local Club: SMOC
Posted 09 August 2008 - 07:04 PM
Right that Vibe sub is Vented for sure.. i'm just waiting to find out what the vent size is.
by the way the BLACKAIR MKIII is now out and retails from Real online shops (not ebay) for only £30 more..
#8 jwb_moto
jwb_moto
  • 1,387 posts
  • Local Club: PMOC
Posted 09 August 2008 - 09:21 PM
I want to make an enclosure that mimicks the lower part of the rear seat but obviously slightly thicker and fit 2 subs in t it. Im just reying to work out how much thicker it has to be.
Is that sub a fair buy for th money? or is the MKIII the way forward or anything else you can recommend for around that budget??
sorry for being a bit thick
#9 Mark@IR
Mark@IR
  • 380 posts
Posted 10 August 2008 - 06:54 AM
If you saved up a little you could get some shallow mounting subs, making your installation a little easier. Hertz also do a nice sub at £100 that'll work well in tight spaces.
#10 Ruckus
Ruckus
    Ice Ice Baby!!!
  • 2,071 posts
  • Local Club: SMOC
Posted 10 August 2008 - 04:04 PM
Or you could push the boot out and buy one of the best SQ sub made.
http://cgi.ebay.co.u...86.c0.m14.l1318
The 12" is 80mm deep and will mount in 100mm :P uber slim.. and will sound :rolleyes: :) :)
Edited by Ruckus, 10 August 2008 - 04:04 PM.
#11 Ruckus
Ruckus
    Ice Ice Baby!!!
  • 2,071 posts
  • Local Club: SMOC
Posted 12 August 2008 - 10:11 AM
OK this is from Fraz at Vibe the gap should be no less than 24mm..
