Sorry To Ask Again! But Help Me!
Posted 10 August 2008 - 12:22 PM
i know this has been asked a lot of times but was is the spark plug gap for a standard mini city 998cc 1989!!
ive searched everywere and totally random stuff comes up.
sorry to waste your time
thanks!!
Posted 10 August 2008 - 01:02 PM
Posted 10 August 2008 - 01:07 PM
Posted 10 August 2008 - 06:46 PM
Champion N12YCC ............................ 0.8 mm (0.032 in)
Champion N12YC ............................... 0.6 mm (0.024 in)
Personally I prefer NKG plugs myself though. So BP6ES would be the ones to fit I think?
Posted 10 August 2008 - 07:02 PM
1000 engine (99H) 1987 on (Champion N12YCC or N12YC)
cheers people thanks
Posted 11 August 2008 - 06:44 PM
What would be the gap setting needed for NGK BPR6ES? I've searched hi and lo on the interweb and come up empty handed.
Fresh out of the box they measure up as 0.032in / 0.81mm
Thanks in advance
Edited by fandango, 11 August 2008 - 06:47 PM.
Posted 11 August 2008 - 07:14 PM
Thanks in advance
Well you shouldn't really be using NGK BPR6ES Spark Plugs on a 1989 Mini Mayfair. The 'R' denotes that they are resistor plugs for cars fitted with electronic ignition. I'd say NGK BP6ES would be more suitable?
I know that the plug gap for a 1275 Mini & Mini Cooper is 0.85mm (0.035in).
Posted 11 August 2008 - 07:22 PM
Ignition System
Spark Plugs: -
Type:
All models up to 1986 ................................. NGK BPR6E
998 cc engine models, 1987 to 1989 ............ NGK BP4EY
998 cc engine models, 1989 onwards ........... NGK BPR4ES
1275 cc engine models, 1991 onwards .......... NGK BPR6E
Electrode Gap .............................................. 0.8 mm .......... (0.032 in)
But I'm not sure that I absolutely believe the new Haynes manual because it contradicts the information that's recorded in my actual Mini handbook.
Edited by taffy1967, 11 August 2008 - 07:29 PM.
Posted 11 August 2008 - 07:54 PM
6 is the one to use in my opinion.
BPR (resistance) will only make a difference if you have electronic ingnition and you experience whining through your stereo.
I have the Petronix setup and use NGK BP6 with 0.035" gaps without problems.
This article might help some one understand spark plug heat ranges
A bit off topic but, what heat range are the forced induction minis using?
Posted 11 August 2008 - 07:59 PM
http://www.somerford...tter-Models.pdf
Posted 11 August 2008 - 10:12 PM
I think Somerfords pdf on 'Spark Plugs' is probably more accurate too: -
Thanks for all of your knowledgeable replies. I've ended up with the BPR after a local motor factor looked up the correct plugs.
Having just looked at the original Austin Rover handbook it suggests GSP 4382 with a gap of 0.025in/0.65mm.
I am now somewhat confused... I'm tempted to use the plugs I have, with the current 0.032in gap.
Let me know now before I do any damage!
Posted 12 August 2008 - 01:04 PM
The gap is slightly larger on those plugs because they suit a range of cars I should say?
