Tie bars
Posted 19 June 2005 - 09:23 PM
Secondly, I believe clubby+roundnose front subframes are different, but will tie bars off a roundnose go onto a clubby?
Posted 19 June 2005 - 09:38 PM
Well, if you can adjust the tie bar so its exactly the same length then you shouldn't mess it up. But I would always have the tracking set up after doing something like that.My wheel alignment needs doing but my front tie bars are a bit bent. If i get the alignment sorted will it get screwed up when i subsequently replace the tie bars with straight ones?
And I hope the Clubby and roundnose subframes aren't different as I'm half way through changing one now!
Posted 19 June 2005 - 11:41 PM
Posted 20 June 2005 - 08:05 AM
Posted 20 June 2005 - 08:30 AM
Adjustables are only necessary if you intend on changing to -ve/adjustable camber bottom arms or you intend on doing track racing...
As for the price adjustables cost IRO £30 a corner when including bushes and standard ones are about £12.
**edit** and yes the subframes are the same ( as long as you dont try and put a MK1/2/3 subframe into a MK4 on shell, change over about 1976 )
Edited by GuessWorks, 20 June 2005 - 08:33 AM.
Posted 20 June 2005 - 10:00 AM
Posted 20 June 2005 - 11:15 AM
Posted 20 June 2005 - 08:40 PM
Tell me about it, but by heck, it's funBent tie bars are unsafe and should be replaced ( also MOT failure point )
Getting mine done shortly, what do you recommend taking into account of me putting a 1380 (100bhp for £400 :grin: ) later in the year
Posted 21 June 2005 - 10:53 AM
Posted 21 June 2005 - 11:11 AM
Posted 21 June 2005 - 03:34 PM
duno where you buy your stuff from john! mine where, 22 sqwid! from min-itsAs for the price adjustables cost IRO £30 a corner when including bushes and standard ones are about £12.
