Im Getting Lag When Accelerating
15 replies to this topic
#1 minibeefy
minibeefy
  • 171 posts
Posted 12 August 2008 - 07:25 PM
mini city E
B reg
998
KnN
twin DTM
hey guys as you prob all know iv had some problems with my mini lately. iv got it runnin and it drives but its been suffering from lag for a while. if i put my foot down it rumbles for a bit then pulls good.
anyone know why this is?
#2 Nickh_16
Nickh_16
  • 724 posts
  • Local Club: Pembs
Posted 12 August 2008 - 07:28 PM
might need and upgraded needle to get more fuel in i had a similar problem, poot my foot down and got nothing for a few seconds, changed the needle goes much better now
#3 sazal
sazal
  • 3,512 posts
  • Local Club: DCMOC
Posted 12 August 2008 - 07:29 PM
You had it rolling roaded?
#4 minibeefy
minibeefy
  • 171 posts
Posted 12 August 2008 - 07:40 PM
na havent had it on the rolling road. need the cash to do it. think i do need a stage 1 needle because thats the only thing that i havent done to make it a stage one.
#5 Nickh_16
Nickh_16
  • 724 posts
  • Local Club: Pembs
Posted 12 August 2008 - 07:49 PM
yeah, could cure the problem, did with me, i had the stage 1 needle but because i also had a cooper head the stage 1 needle wasn't enough, so i upgraded again and now it runs like a dreaaaaaaaaam
#6 minibeefy
minibeefy
  • 171 posts
Posted 12 August 2008 - 07:50 PM
also my engine moves because the bushes have gone. am i right these r the right ones to buy?
CLICKY
#7 minibeefy
minibeefy
  • 171 posts
Posted 12 August 2008 - 07:54 PM
does the cooper head give much more power?
is there much modifications needed to fit one?
#8 JohnGordon
JohnGordon
  • 966 posts
  • Local Club: N.W Mini's / O.D.M.C
Posted 12 August 2008 - 07:56 PM
I know this sounds stupid but have you taken the spacer off the carb assembly? I had to, to fit my piper-cross air filter. This did cause the accelerator mechanism to catch on the inlet manifold (just another thing to check)
#9 Nickh_16
Nickh_16
  • 724 posts
  • Local Club: Pembs
Posted 12 August 2008 - 07:58 PM
the 12G295 cooper head is what i have, it was a straight on job, had it skimmed to get a clean surface first, apparently they're supposed to be skimmed 40thou first to get teh correct compression ratio, but you should ask someone else about that, mine works fine, i think it gives quite a reasonable power gain, mine goes well and pulls through the gears very well, i've never driven a standard 998 so i wouldn't be able to compare i'm affraid
nick
#10 minibeefy
minibeefy
  • 171 posts
Posted 12 August 2008 - 07:59 PM
im not sure what spacer u mean, but as far as i know i havent taken anything off.
#11 Surfbluegarage
Surfbluegarage
    AKA mini_mad_daps
  • 1,547 posts
Posted 12 August 2008 - 09:19 PM
just another thing to check for is your advance on your dizzy mine has failed acouple of times on minis and causes the engine to not pull much at certain revs. test it with a vacumn pump if u can get one and make sure it holds it vacumn if u havent got a pump then take the advance pipe off the carb suck on it and put your tongue on the end if it sticks to your tongue for a couple of seconds its ok.if not ring h+h or aldon or sumone for a new one.
#12 MiniMonty
MiniMonty
  • 1,802 posts
Posted 13 August 2008 - 01:07 AM
Your exhaust is probably your problem if it hasn't been fitted with all the bits and bobs to marry
it happily to the engine. (i.e. needle/manifold etc.,)
But hang on....
Sounds like you are talking about a flat spot in the engine and that will need tuning out when you get a needle anyway so you could
get a slightly sweeter ride now and a good 'practice' for the tuning you will need to do when you do get the needle.
I'd start with really carefully and precisely doing the valve clearances. Take your time over this
and do it right. (i.e very slowly and carefully). Gap the points precisely and run her down to a nice low idle with the carb screw so that when standing
a few feet away with the bonnet off or open the main sound you hear from your engine is a regular and rhythmic "tick-tick-tick-tick-tick-tick-tick-tick".
Go round the block a few times and get the engine up to temp and see how she pulls.
Go home and do your valves again (they will have moved minutely).
Obviously, before you do any of this look for punctured hoses, bad gaskets etc.,
But, as others have suggested, you probably need a needle and a rolling road to get the most out of it.
by the way - if your exhaust is loud on a 998 you are losing power and speed to the God of showing off.
I prefer being quiet - and first.
Best wishes
Monty
#13 998dave
998dave
    998cc's Of Dave Goodness
  • 4,566 posts
  • Name: Dave
Posted 13 August 2008 - 11:08 AM
CLICKY
Yes those are the right bushes, you'll need two sets, one for engine, one for bulkhead.
I tend to buy mine from Mini-Medics though, very helpful and quick.
If you have the wrong needle then you'll be down on power, and running lean, it's only £10, so get one, fit that, and try setting it up again. Then look at rolling road to get the best.
Changing the head will make things worse until you've got the right needle.
Also check oil in your dash pot while you're at it, and your points and ignition system, plug gaps, point wear, how long ago were these last changed or checked? They're regular service items on the A-series, unles the basics are working right any tuning mods are a waste of time and money...
Dave
#14 Mart8V
Mart8V
  • 505 posts
Posted 13 August 2008 - 12:15 PM
Agree with Dave- oil in the dash pot is the first and easiest fix! Was having problems with my old HIF38 with a massive flat spot and discovered it was totally dry in there. Sorted out straight away.
#15 minibeefy
minibeefy
  • 171 posts
Posted 13 August 2008 - 06:46 PM
CLICKY
Dave
iv only just changed the points and the dashpot has oil in it. guess il need a new needle and a RR session.
