Model:1275 Sprite
Year:1993
I recently acquired this low mileage 1275 Sprite and on Saturday I took it on its first long trip. Although it rained it ran fine and got home with no problems. However when I came to start it on Sunday morning, it turned over but would not fire. There was no spark either at the plugs or the HT lead coming from the coil. So I have just fitted a new coil, distributor and rotor arm - and it still won't spark. Ignition is by an electronic unit on the side of the distributor and the coil has two white/black wires and two white wires running to it. One black and one white/black wire come from the ignition unit. The coil is getting hot with the ignition on and there is strong spark when I pull off one of the white wires or one of the white black wires, so current is flowing to the coil, but neither produces a spark from the HT lead to the block.
Could it be the electronic ignition - according to the Haynes manual they should be trouble free but I cannot think what else could have gone wrong between driving home on Saturday and it failing to start on Sunday.
Any help would be greatly appreciated as I am at a complete loss with this one.
Any non-standard parts that might be involved with the problem? None I know of.
Edited by steve_hobnob, 12 August 2008 - 09:01 PM.
