Brake Pipe Flaring Tool
10 replies to this topic
#1 minidan
minidan
  • 2,354 posts
  • Local Club: LSMOC
Posted 13 August 2008 - 06:30 PM
does anyone know how to get good flares using the pictured brake pipe flaring tool?
i have had to buy one to make some custom length pipes on my vtec project mini but just cant get the flares right.
#2 minijazz
minijazz
  • 173 posts
Posted 13 August 2008 - 06:54 PM
Hi Dan
I have the same tool as the one in the photo. All I can suggest is to have a cuppa and read the leaflet that comes in the pack.
Then practice- I used about 6 feet practicising- the copper tube is not that expensive.
cheers colin
#3 minidan
minidan
  • 2,354 posts
  • Local Club: LSMOC
Posted 13 August 2008 - 07:34 PM
yea the trouble is i didnt get any instructions or leaflets with the kit... :wub:
can you give some idea how to start? any tips? what does the leaflet say anyway ?
#4 Ethel
  • 26,060 posts
Posted 13 August 2008 - 07:44 PM
Manufacturer's website?
Not the same as mine, but general points...
De burr the pipe end,
Clamp the pipe solidly, I put the tool in a vice.
Getting the correct length of pipe to form the end on is important. Instructions would help here.
#5 minidan
minidan
  • 2,354 posts
  • Local Club: LSMOC
Posted 13 August 2008 - 07:56 PM
the tool i have has 'JAKS' on the box. got it off ebay...
#6 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 13 August 2008 - 08:11 PM
Put the pipe in to right size hole, clamp tight, so the top of the piupe is flush with the surface of the clamp. Put the correct size die into the hole, put the clam over it and tighten it. You need to do it again with a different die if you need a double flanged end. It is possible to get a good end with those, but not too easy. The bench mounted type are best, I have a bluepoint one, cost about £100 but it's fantastic.
#7 Pauly
Pauly
  • 4,213 posts
Posted 13 August 2008 - 08:33 PM
Got mine from machine mart, I did a couple of practice runs before I did my first one, and to be honest, I get some really good flares, make sure the everything is straight before flaring.
Paul.
#8 john1.2pearl
john1.2pearl
  • 341 posts
Posted 13 August 2008 - 08:58 PM
And make sure you put the fitting over the pipe before you press your last flare :wub: , Has been done all too many times ! (Not that ive done it before ;D )
#9 minidan
minidan
  • 2,354 posts
  • Local Club: LSMOC
Posted 14 August 2008 - 05:25 PM
im not sure what you mean here, the brake pipe is 3/16" and all the other dies are bigger so how can you use a different die to finish the flare?
#10 Ethel
  • 26,060 posts
Posted 14 August 2008 - 05:39 PM
You get male and female flares, looking at an old brake pipe or 2 will make it clear. The females are made by making a male then using a second die to push the centre down to make the cone shape.
Edited by Ethel, 14 August 2008 - 05:44 PM.
#11 Strontium Dog
Strontium Dog
  • 178 posts
Posted 16 August 2008 - 07:28 PM
That type of tool works fine as long as you clamp it in a vice and don't rely on the butterfly nut that they come with. The pipe tends to slip through if you don't get the clamping tight.
