My clutch slips but not when you'd expect it really. In 1st, 2nd and 3rd i can floor it and the clutch won't slip at all but then in 4th at high revs - high speed the clutch will slip and the revs will just zip right round without the car accelerating.
This is only really a problem on motorways. The clutch will slip in third going up the sliproad - Making it difficult to get up to speed, i just have to sit at about 40mph until i can get to the top. Then i change to fourth put my foot down and it'll be fine up to about 60, then past that the revs will just rise by about 1000rpm more than they should.
Even after a 30 second stint on the motorway all you can smell is burning clutch.
Is there anything i can try and adjust first?
If not what do i need to replace? Is it just the plate or a full clutch kit i need? (£££)
