High lift cam
1 reply to this topic
#1 TimS
TimS
    Mini Doctor
  • 2,712 posts
Posted 22 June 2005 - 10:29 AM
I was just wondering what you guys set you tappets to on your non std cams.... I used to run it as .30mm and rang morspeed for this cam and said about 16 thou which is .405mm does this seem about right?
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 22 June 2005 - 10:36 AM
I've always set mine to 15 thou (sorry dont do metric), and 12 thou on std
Kent cams say .4mm for the 296 which is 15.7 thou
