Fiberglass Repairs?
6 replies to this topic
#1 chris_gilly
chris_gilly
  • 571 posts
Posted 19 August 2008 - 02:18 PM
hi, i have a few little holes on my outer sills everything else is solid...the biggest on is prob the size of a £2 coin,
can i use fiberglass to fill the holes then filler, would this be ok for the MOT?? as i need my car on OTR ASAP!!!
then i would simply replace the whole sills when i get the time...
any help/info would be brill
chris
#2 chris_gilly
chris_gilly
  • 571 posts
Posted 19 August 2008 - 03:16 PM
chris
can anyone help???
#3 Ethel
  • 26,104 posts
Posted 19 August 2008 - 04:21 PM
Only if the Tester doesn't notice :).
A fully seam welded patch would be ok but if there's a hole due to corrosion it's highly likely much of the rest of the sill is lacking strength even if it's not rotted through.
#4 chris_gilly
chris_gilly
  • 571 posts
Posted 19 August 2008 - 04:29 PM
ok cool, ill prob patch it on the weekend...
thanks for the advice!!!
#5 Ouster
Ouster
  • 2,986 posts
  • Local Club: Looking
Will probably get you through the MOT, but widely regarded as a bodge job!
Much better to do it properly now rather than doing it "when you get round to it".
#6 chris_gilly
chris_gilly
  • 571 posts
Posted 19 August 2008 - 05:14 PM
yeah, ive decided im going to weld patchs on it for now, then hopefully i will replace them to cure the problem.(for a while anyway)
thanks
#7 MiniLuke
MiniLuke
  • 1,205 posts
Posted 19 August 2008 - 06:08 PM
chris
I think you need to repair this properly, there is a reason why the holes would fail an MOT, it will almost certainly means the rust is far reaching in the sills and could be structurely dangerous. Fibreglass and filler are not the answer.
