Dash
Posted 22 August 2008 - 12:08 PM
thanks
Posted 22 August 2008 - 12:12 PM
Edited by Git, 22 August 2008 - 12:12 PM.
Posted 22 August 2008 - 12:17 PM
Posted 22 August 2008 - 12:20 PM
i want to remove the 'pretty' rail cover to expose the metal rail
There's a switch penel under it.
Posted 22 August 2008 - 12:25 PM
Posted 22 August 2008 - 12:29 PM
Posted 22 August 2008 - 12:53 PM
Posted 22 August 2008 - 01:02 PM
& If you mean the top dash rail there are 3 nuts holding it together, and will pull of once you have undone them, But watch out there maybe some rust lurking underneath!
Edited by Racer_Pete, 22 August 2008 - 01:06 PM.
Posted 22 August 2008 - 02:51 PM
If your talking about the bottom dash rail you can remove it. But once its removed the dash pannel will be sticking out roughly an inch in front of the bare metal, unless you modify it so it fits flush.
thanks for the info. im talking about the bottom rail cover. to uncover the yellow bit in the pic. does anyone know how its attached
Edited by The Mod Wolf, 22 August 2008 - 02:52 PM.
Posted 22 August 2008 - 03:33 PM
i done this a cupple of days ago and i think you will find that its glued in place as my one would not come off in one pice its made from a type of foam and is glued hevley in the cnter where the switch panel is
Posted 22 August 2008 - 03:36 PM
not a hard job. had ours out in 15mins, but then i wanted the dash cover so was gentle so it didnt break.
Posted 22 August 2008 - 03:38 PM
Yeh, It's pretty hard to get them off in once piece as when you try to get it off the foam bends and folds in where the switch pannel is, Maybe just take your time if you want it to come off without any marks.
Posted 22 August 2008 - 07:12 PM
Paul.
