Hosepipe Blew Up!1!
7 replies to this topic
#1 daniel323
daniel323
  • 18 posts
  • Local Club: malta mini club
Posted 24 August 2008 - 01:28 PM
after 3 months of sitting around int he garage i wanted to start the engine of the mini and i noticed it was runing low on wate so i topped it up.
i went for a drive and when i came back i noticed the engine overheating.. this morning i retoped it whit water and went for a littel spin around the block to see if it was a leaking hosepipe. when i was on the road back the back hose pipe that is connected to the bottom of the rad to the pump blew up i ****** on me self lol.
its like it got pressured the engine was rebuild just few months ago whit new every thing so i dont know what can be wrong??
the rad is refurbished and there is no mayo stuff under the oil tap and engine oil seems fine!!!!
any suggestion?
tnx for the help
Edited by Dan, 24 August 2008 - 02:09 PM.
Langauge. I'll leave the spelling and everything else.
#2 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 24 August 2008 - 01:41 PM
Perhaps it was an air-lock? Try running the engine (from cold) with the radiator cap removed for a few minutes until the coolant starts to bubble and then replace the cap.
#3 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 24 August 2008 - 02:11 PM
The system is meant to be pressurised, that's how it works. Old hoses fail, no mystery really. Replace it.
Please don't swear in our forum.
#4 Strontium Dog
Strontium Dog
  • 178 posts
Posted 24 August 2008 - 04:20 PM
You only get mayo when the water ways connect to the oil ways! It is likely the head gasket has blown to a waterway unless the hose was old. As you say it has just been rebuilt I would assume any duff hoses would have been replaced at tyhe same time!? Most garages can do a test on the coolant to see if the HG has gone.
Edited by Stronteum Dog, 24 August 2008 - 04:21 PM.
#5 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 24 August 2008 - 04:46 PM
Mayo can also be attributed to lots of short jurneys..so dont take it as definite proof your Head gaskets gone
#6 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 24 August 2008 - 04:53 PM
He says there is no 'mayo' there!
Very often a newly built engine with new everything is anything but. Nobody sells an engine with ancilliaries and most of the time if this work was doen by a garage the old hoses would be used.
#7 danny2009
danny2009
    Previously 'gerrard'
  • 1,069 posts
Posted 24 August 2008 - 06:07 PM
mayo lol have a check of the pipes they may not have replaced the pipes o the pepes mite not have been tite an come off because of the pressure
Edited by gerrard, 24 August 2008 - 06:13 PM.
#8 daniel323
daniel323
  • 18 posts
Posted 25 August 2008 - 04:16 AM
i am suspecting that the rad cap can have something to do because now i remember i used a slightly bigger one that has a slightly bigger rubber seal?
could that be one of the problems to ?
yes the hose pipe want new i new that i didn't buy a new one becouse i was gonna buy a new silicone hose set. some bling you know hehe. i will try buy a new one today. and lets see what happens.
