Putting a stage 3 head on my engine today, all going swimmingly until it came to putting to pushrods back in. 7 of them have gone in fine and dropped to their "normal" positions, however one (furthest away pushrod to the radiator) is refusing to go in. Any ideas what I can do?
One Pushrod Won't Drop Down!
Ouster
, Aug 26 2008 03:04 PM
5 replies to this topic
Posted 26 August 2008 - 03:04 PM
Posted 26 August 2008 - 03:10 PM
Only thing I can think if is when you removed the push rod originally it pulled the cam follower up with it which has then fallen off and blocked the hole ! If your engine is a 998 then you can simply take the tappet cover off the back and have a look. If its a 1275 then get a torch and look down the hole to see what you can see. You might be able to fiddle it back into position with a screwdriver and / or a magnet.
Tip for next time....twist the pushrod first to break the possible seal with the cam follower before pulling it out.
Edited by Grayedout, 26 August 2008 - 03:10 PM.
Posted 26 August 2008 - 03:13 PM
yeah,
thats happened to me before so ill second that!!
Posted 26 August 2008 - 03:18 PM
how far will it go? could it be that it is sat on the top of the cam lobe?
Posted 26 August 2008 - 03:19 PM
Other thing it could be is that the head gasket still has the cut-out for the pushrod in situ. OK if it's 998 - stinker if it's 1275.
Posted 26 August 2008 - 03:30 PM
Bingo! It was the cam follower, it had fallen over - the suction must have lifted it off.
All sorted now though! Now for the annoying bit - exhaust.
Thanks.
Thanks.
