Deseaming
Posted 26 August 2008 - 06:47 PM
i hear its a hard task why is this
and how much would a body shop charge ?
Posted 26 August 2008 - 06:53 PM
Posted 26 August 2008 - 06:56 PM
Posted 26 August 2008 - 07:09 PM
Use the search there has been lots on this in the past.
Edited by Ro8bieg, 26 August 2008 - 07:15 PM.
Posted 26 August 2008 - 07:15 PM
well, they hold the car together. on other cars they are on the inside but the mini was designed with them on the outside.
to de-seam a mini means to remove the bits that are holding it together, so you have to replace them with something that's done properly, (not sure your dad is going to like the idea of that).
it can be done but its not something that you can do with a "quick fix", and while I'm here i might as well add.... i think it looks naff
seems there is nothing you won't consider doing to your poor old mini
Posted 26 August 2008 - 07:23 PM
Posted 26 August 2008 - 07:35 PM
Posted 26 August 2008 - 07:56 PM
Posted 26 August 2008 - 08:09 PM
Posted 26 August 2008 - 08:24 PM
im wanting to remove the lip on the rear where the bumper would have gone! what should i do to make shure it doesnt fall to bits! will welding a plate behind it do?
That would stop it falling off, but it would look rubbish. The seam needs to be welded solidly from behind before you remove the lip, then the lip will need a lot of work finishing it to stop it looking rubbish.
Posted 26 August 2008 - 08:29 PM
Posted 26 August 2008 - 08:40 PM
Posted 26 August 2008 - 08:49 PM
Posted 26 August 2008 - 08:51 PM
Posted 26 August 2008 - 09:00 PM
