Deseaming
25 replies to this topic
#16 tobiasnugent
tobiasnugent
  • 763 posts
Posted 26 August 2008 - 09:06 PM
i dont think ill get it done due to the money and risks
#17 Piddling Kid
Piddling Kid
  • 202 posts
Posted 26 August 2008 - 09:47 PM
like panelbeater said its not that hard if you take your time and are pretty good with a welder, i wouldnt trust a bodyshop to do it id only do it myself then you know what standard it has been done to.
#18 matty121
matty121
  • 296 posts
Posted 26 August 2008 - 10:04 PM
is welding on the inside of the seem a necessity? or can you get away with only welding externaly?
if i was goin to de-seam my car which i will do in the near future i would definetaly install some sort of cage to compensate
#19 Retro_10s
Retro_10s
    Moderator
  • 10,176 posts
Posted 27 August 2008 - 09:47 AM
Depends,... if your welding is good enough, then you should be confident that you're getting good penetration through the panel, But plating is a good practice to apply and is some extra peace of mind. Plate what you can get to (which is essentially just the back end seams)
I would definetaly install some sort of cage to compensate
A cage is a good idea in any mini but i certainly wouldn't see de-seaming as a reason to fit one... unless it's been done very shoddily. With blue tack and bean tins :)
Edited by Retro_10s, 27 August 2008 - 09:55 AM.
#20 matty121
matty121
  • 296 posts
Posted 27 August 2008 - 09:52 AM
compensate for what?... If you weld it up properly which do you think is stronger? something that has no seams, or something that's seamless.
thats a point i guess it all depends on how good your welding skills are, how strong it will be
#21 bert998
bert998
  • 2,558 posts
Posted 27 August 2008 - 10:00 AM
i'm going to deseam my 1972 all original clubman. Just to nark anorak off :)
#22 THE ANORAK
THE ANORAK
  • 3,946 posts
Posted 27 August 2008 - 04:02 PM
i'm going to deseam my 1972 all original clubman. Just to nark anorak off ;)
and I'm going to order my brand new interior from newton commercial.... just to nark bert998 off :)
:dontgetit:
Edited by THE ANORAK, 27 August 2008 - 04:02 PM.
#23 bert998
bert998
  • 2,558 posts
Posted 27 August 2008 - 06:48 PM
and i thought you were going to totally go balls out and customise it ;)
:dontgetit:
#24 woody17
woody17
  • 432 posts
  • Local Club: three valleys mini club
Posted 27 August 2008 - 07:20 PM
mr. v says do a small section a t a time, to hold the car panels in place. like 6 inches, cut of, then weld up.
also it takes of 40inches of frontal drag!
#25 5MITHY
5MITHY
  • 218 posts
  • Local Club: Minis n Oatcakes
Posted 28 August 2008 - 06:19 AM
i'm going to deseam my 1972 all original clubman. Just to nark anorak off :-
oooh, cheap shot :) ;)
#26 norwegianminiman
norwegianminiman
  • 323 posts
  • Local Club: norwegian mini cooper club
Posted 28 August 2008 - 06:16 PM
I must say im in the anorak school of thinking when it comes to deseaming... think it makes the car look... wrong...
