:erm: Help... right, here it goes.... because i bought my sub ( Pioneer TS-W304C 12" ) and amp ( Sony XM-440NX )off a mate #1 i dont no if the amp works, is there a way of testing it without having to wire the whole thing up in my car? and #2 how do i wire it all up anyway, as i have no instructions, also, should i bother wiring it up as i dont have a decent headunit as of yet. if any one has any diagrams of how to wire these up please send them to me. or the instructions to either. thanx :cheese:
Need Help again...
pip308
, Jun 26 2005 03:06 PM
4 replies to this topic
Posted 26 June 2005 - 03:06 PM
Posted 26 June 2005 - 03:48 PM
rite the quickest way I find to test if the amp works is to run a remote turn on cable from the iso block out the window along the outside of the car and into the boot where the amp is. Ground the amp to them - terminal on the battery and then run the live to the amp. turn the ignition switch so the hu turns on and go check there is a power light on and check to see to make sure there is no protection light on. then in it should be fine to use.
As for wiring u need to use the right awg cable for the power of the amp. The wiring is broken down like this:
Ground:
Bolt one end to some bare metal and take the other end to the terminal on the amp marked GRD this cable is normally black
Remote:
connect one end to the remote turn on coming from the iso block on the back of the HU then wire the ither end to the REM terminal this cable is normally blue.
Live:
Take this wire (red normally) with the right inline fuse for the power as close to the battery as possible from the + terminal on the battery to the 12v terminal on the amp.
RCA's
Ur amp now works but u need to send it signals for music, for this u need a set of rca's to run from the back of ur hu to the amp these will be white and red/L and R
Take a pic if u can of both sides of ur amp and I will lable the photo's up for u so u know what everything does.
Ground:
Remote:
Live:
RCA's
Posted 26 June 2005 - 04:10 PM
i dont have a digital camera but i found this pic... its a bit small tho
Posted 26 June 2005 - 05:45 PM
Right can't really mark out that pic can u scan a image in or summit, as for rca's c the blue silver cable on the left of the amp there that rca leads u need them to send the front/rear and left and right signals to ur amp. As for the iso block if u pull ur HU out u will should notice two black rectangle shapes in the back with all the wire going into there should be a spare wire coming out of 1 that is connected up to anything usually orange or blue this is ur remote lead.
Posted 26 June 2005 - 09:34 PM
i jus spent the the last hour on the fone to my Mrs so i thought i'd use the time effetively, so i did this diagram of my amp.... :smartass:
