Carbon Fibre Bond
Posted 27 August 2008 - 01:12 PM
the name tiger bond or sonthinks like that rings abell.
do's any one know
Posted 27 August 2008 - 02:01 PM
I wouldn't trust it to hold your roof on with sufficient strength though! Is it just a skin your fitting?
Edit: Obviously you should also use rivets or fastenings when fitting the above mentioned parts, Tiger Seal on its won won't do much in the longrun!
Matt.
Edited by Waffs1984, 27 August 2008 - 02:03 PM.
Posted 27 August 2008 - 02:02 PM
Athough, admittedly I havent stuck a roof down with it :/
Edited by BadgerBaiter, 27 August 2008 - 02:10 PM.
Posted 27 August 2008 - 02:11 PM
Posted 27 August 2008 - 03:37 PM
http://www.theminifo...x...4730&st=105
I might be getting one for my project aslong as the missus doesn't find out how mucht they are.
Posted 28 August 2008 - 06:06 AM
do's any one know of any think stronger.
Sikaflex 221 is always quite highly rated for panels, though I've been told Tiger seal is quite similar but cheaper.
Did a test with a couple of bits of perspex and some 221 and was amazed how good the bond was. If it's a roof skin over a normal metal roof the loading on the skin won't be all that high (mainly parasitic drag - which will be fairly small if its a shiny exposed carbon weave), main thing to ensure is that you get a good tight, sealed fit all round but particularly at the front to avoid air being forced under the skin and prying it off.
Put up some photies when its done plesae!!
**EDIT: After reading your post and the other replies again, I get the impression that you are talking off replacing the roof entirely with a carbon one? If so, definatly don't just Sikaflex/tigerseal it as there will be too much movement and not enough strength, as the stuff is flexible to a degree**
Edited by benno, 28 August 2008 - 06:13 AM.
Posted 28 August 2008 - 06:45 AM
Posted 28 August 2008 - 09:25 AM
cheers del
Posted 28 August 2008 - 09:43 AM
