Filter King And Fuel Regulator
1 reply to this topic
#1 sean1380
sean1380
  • 167 posts
  • Local Club: kendal mini club
Posted 27 August 2008 - 06:39 PM
im struggling gettin blue flame on clourtune on my car iv got a reece fish carb being fed by a facet fuel pump but i thought the pressure might be too much no matter how much i adjust i cant get a lean mix only gettin it at idle,
how do i adujst the pressure on the filter king or is it set?
will timing be out effect this?
timing for a swiftune sw05-07,what should it be?before or after tdc?
#2 rofert
rofert
  • 140 posts
  • Local Club: Cardiff Mini Club
Posted 27 August 2008 - 09:33 PM
The pressure on a filter king is adjusted by removing the dome nut on the top, loosening the lock nut and adjusting the screw. To get it accurate you will really need either a pressure gauge fitted in line or one you can place the outlet from the filter king on to. Dependent on your state of engine tune and what you are using the car for probbably you should be looking for about 2psi from it.
Rofert
