A+ Engine Nuts, Bolts And Screws
9 replies to this topic
#1 codd_coupe
codd_coupe
  • 41 posts
  • Local Club: GTMOC
Posted 27 August 2008 - 09:10 PM
Does anyone have a list of all the nuts bolts and screws needed to put the engine, gearbox, wok, etc with ancilleries back together? I have just refurbished the whole engine and gearbox and the old screws etc now look grubby (and I'm sure some are missing!).
I know there used to be a list on minifinity, but I think it has gone missing since their server crashed.
Any help gratefully received.
#2 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 27 August 2008 - 09:16 PM
Yes, all the Mini specialists do. They're called parts manuals. The list would be different for almost every different engine number, what would be the point in typing all that up when there are manuals already available?
#3 Ethel
  • 26,073 posts
Posted 27 August 2008 - 09:19 PM
like this one ;)
http://www.moss-euro...RESTORATION.pdf
#4 Sleepy Stu
Sleepy Stu
    formerly Stewart_GT
  • 2,564 posts
Posted 27 August 2008 - 09:25 PM
Yeah i know what codd means though would be awesome if you could just buy like a job lot that included all the nuts and bolts needed even if you did have to pay a bit more cause it included some that you didnt need.
Until then start writing down those part numbers! ;)
Edited by Stewart_GT, 27 August 2008 - 09:26 PM.
#5 MarkGTT
MarkGTT
  • 528 posts
Posted 27 August 2008 - 09:28 PM
And breath - thats a bit on the sarcastic side.
#6 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 27 August 2008 - 09:29 PM
Only a bit? ;)
#7 Surfbluegarage
Surfbluegarage
    AKA mini_mad_daps
  • 1,547 posts
Posted 27 August 2008 - 10:25 PM
just out of interest on this thread are the threads on the A+ the same that hold the box to the block throughout the castings or do they differ in anyway? if so does anyone know they sizes they used? just threads not bolt lengths?
#8 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 27 August 2008 - 10:59 PM
The gearbox to block bolts, screws and studs are always 1/4 UNF. A popular race upgrade has always been to uprate them to 5/16 unf so if you have an odd size that may be the cause. Oh and one of them is a nut and bolt through a hollow dowel.
Edited by Dan, 27 August 2008 - 10:59 PM.
#9 codd_coupe
codd_coupe
  • 41 posts
  • Local Club: GTMOC
Posted 28 August 2008 - 06:01 AM
The guys on turbominis sorted this one out, here is the original list from minifinity:
Timing Cover
5 x Bolts Cap Head 5/16"UNF (3/4" Long)
6 x Bolts Cap Head 1/4"UNF (7/16" Long)
5 x Washers 5/16"PLN (5/8" OD)
5 x Washers 5/16"SPR (1/2" OD)
6 x Washers 1/4"PLN (9/16" OD)
6 x Washers 1/4"SPR (7/16" OD)
1 x Nut 5/16"UNF (1/2" Head)
1 x Nut 1/4"UNF (7/16" Head)
Coolant Circui
2 x Bolts Heater Tap 1/4" UNF (7/16" Head, 1/2" Long)
2 x Washers Heater Tap 1/4" SPR (3/8" OD)
2 x Bolts Radiator Top 1/4" UNF (7/16" Head, 1 1/2" Long)
2 x Washers Radiator Top 1/4"PLN (9/16" OD)
2 x Bolts (Water Pump) 5/16"UNF (1/2" Head, 2" Long)
2 x Bolts (Water Pump) 5/16"UNF (1/2" Head, 1" Long)
4 x Washers (Water Pump) 5/16"PLN (5/8" OD)
4 x Washers (Water Pump) 5/16"SPR (1/2" OD)
Thermostat (Short)
3 x Bolts 5/16 UNC (1/2" Head, 1 1/2" Long)
3 x Washers 5/16" SPR (1/2" OD)
Engine Electrical
2 x Bolts (Alt' top) 5/16"UNF (1/2" Head, 2" Long)
1 x Bolt (Alt' Bottom) M8x20
1 x Nut (Alt' Bottom) mate NyLoc
4 x Washers (Alternator) 5/16"PLN (5/8" OD)
4 x Washers (Alternator) 5/16"SPR (1/2" OD)
2 x Nuts (Alternator) 5/16"UNF (1/2" Head)
2 x Bolts Starter Motor 3/8"UNC (9/16" Head, 1 1/4" Long)
2 x Washers Starter motor 3/8"SPR (5/16" OD)
1 x Bolt (A+ Distributor) 5/16" UNF (1/2" Head, 3/4" Long)
Clutch Slave (Non verto)
2 x Bolts (Cyl Mount) 3/8"UNC (9/16" Head, 1" Long)
2 x Washers (Cyl Mount) 3/8"SPR (5/8" OD)
1 x Bolt (Arm Stop) 1/4"UNF (7/16" Head, 1" Long)
1 x Lock Nut (Arm Stop) 1/4"UNF (7/16" Head)
Clutch Cover
8 x Bolts 5/16"UNC (1/2" Head, 1" Long)
8 x Washers 5/16"SPR (1/2" OD)
8 x Washers 5/16"PLN (5/8" OD)
Tappet Chest
2 x Bolts 5/16" UNF (1/2" Head, 1 1/4" long)
2 x Washers 5/16 PLN (5/8" OD)
Pre A+ Distributor Drive
1x Bolt 1/4"UNF (7/16" Head, 3/4" long)
1x Washer 1/4"SPR (3/8" OD)
Fuel Pump 2 x Bolt 5/16" UNC (1/2 Head , 1 1/2"long)
2 x Washers 5/16" SPR (1/2" OD)
2 x Washers 5/16" PLN (5/8" OD)
Oil Filter Housing
2 x Bolt 3/8" UNC (9/16" Head, 1" Long)
2 x Washers 3/8" SPR
2 x Washers 3/8"PLN (15/16" OD)
Manifold Bolts
6 x Bolt 5/16 UNF (1" Long)
6 x Washers 5/16" SPR (1/2" OD)
6 x Washers 5/16" PLN (5/8" OD)
Thanks for all the help though. ;)
#10 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 28 August 2008 - 09:00 AM
I'll check that and FAQ it if you like but I can already see a fair few things missing and a lot that depends on the age of the engine just from a brief look. There's no mention of the transfer gear case at all and the fixings in that are quite specialised after a certain year.
