Rivet Nuts
2 replies to this topic
#1 Pauly
Pauly
  • 4,213 posts
Posted 28 August 2008 - 01:46 PM
Hi guys,
My driver side door has the standard rivnuts for the mirrors but they are loose is there anyway to tighten them up again or do I need to remove them.
If I need to remove them how do I?
Paul.
#2 pantera2075
pantera2075
  • 596 posts
  • Local Club: GTMOC
Posted 28 August 2008 - 02:23 PM
Not a hundred percent sure, but you can normally tighten rivnuts with a bolt of the same thread, and a washer no bigger than the outer of the rivnut. Put the washer on the bolt and tighten it hard into the rivnut - it should tighten it. Otherwise you have to drill it out (very carefully)
#3 m1n1
m1n1
  • 769 posts
  • Local Club: I'm unsociable
Posted 28 August 2008 - 04:26 PM
I used a rivnut insertion tool. Its like a pop rivet tool, except you screw the rivnut onto the thread, insert into hole, squeeze trigger which pulls the nut together, before unscrewing tool.
So yea i just used the tool and squeased it a bit tighter. Job done.
