Does anyone have any idea what size bolt and thread it is that holds the window winder securely on. have found its been bodged with a screw.
Window Winder
MINI7
, Jun 27 2005 05:21 PM
3 replies to this topic
Posted 27 June 2005 - 05:21 PM
Posted 27 June 2005 - 07:00 PM
don't hold me to it but im sure they were fixed on with screws from the factory, and if you locktite them in place they dont come off with vibration
Posted 27 June 2005 - 07:18 PM
Yeah its a cross-head screw that kindof engages a big (inch-ish) plastic hex key into a nut as you tighten the assembly. If thats all there the screw should be sufficient.
Posted 27 June 2005 - 07:23 PM
the thread is a small imperial machine thread, some come with a big flat washer attached and some dont... the only other one which I can think of which is the same size is the one holding the central console ( or blanking plate ) to the bulkhead
