Crank Pulley Removal
3 replies to this topic
#1 lotusk
lotusk
  • 135 posts
Posted 01 September 2008 - 06:44 PM
Hey all,
I am trying to remove the crank pulley on a 1998 mpi but am having a few problems. Tried levering it off with large spanners but no luck. I understand its possible to get pulley removers but i'm concerned about clearance.
If anyone has used a specific pulley remover tool with good results could you let me know which one please? Any other methods of removing it would also be appreciated.
Thanks :P
#2 Sleepy Stu
Sleepy Stu
    formerly Stewart_GT
  • 2,564 posts
Posted 01 September 2008 - 06:49 PM
Hey all,
Thanks :P
Think i ended up using a crowbar in the end IIRC
#3 lotusk
lotusk
  • 135 posts
Posted 01 September 2008 - 06:55 PM
Hey all,
Thanks :P
Yeah I did think about that but a) I dont want to damage the pulley and b) I dont want to damage the timing chain cover...
I presume you had no problems with yours though? Also I understand the newer pulleys have built in balancers - where is this situated and is there anything I need to do to ensure I don't damage it?
Damage, or not damaging seems to be the key theme here :ermm: Thanks for your help.
#4 robba_duck
robba_duck
  • 326 posts
  • Local Club: looking for a new one
Posted 01 September 2008 - 07:07 PM
You will need:
1 x Copper Mallet
1 x Leaver device (large screw driver or sorts
and plenty of bashing and leavering as you bash it will come off then!
and the copper mallet helps not destroy the pulley!
