Alloy Wheel Stripping
Posted 02 September 2008 - 02:32 PM
Nitromors has got through 3 layers of paint but has got stuck on a white layer, it doesnt seem to be able to touch it at all. Ive used quite a bit on the white paint to no joy.
Any tips/advice other products i could use?
Posted 02 September 2008 - 03:00 PM
If you really need it off, then bead/grit blasting is probably the only option.
Posted 02 September 2008 - 03:07 PM
I had the same problem. It just would not touch the primer coat, whatever it is. In the end I just rubbed the other wheels down by hand and painted over the top.
Thats the other thing, ive already used the blaster on the wheels, that didnt seem to touch it either
Posted 02 September 2008 - 04:56 PM
I have a set of mini special alloys.. underneath a few layers of paint there seemed to be an original coating of some sort that was white. It wasnt a primer coat, looked like a factory finish.. but anyway it was hard as nails, took quite a while under an industrial sand blaster to clean them all off proper.
Like said, unless you really need it off, I'd just prep them up best you can (expect bleeding finger ends) and get some primer on to see how they look.
Posted 07 September 2008 - 06:39 PM
Posted 08 September 2008 - 06:28 PM
Posted 09 September 2008 - 08:07 AM
Well ill keep going but is there any way of making it work better?
Posted 09 September 2008 - 12:19 PM
Posted 09 September 2008 - 06:59 PM
