Posted 03 September 2008 - 07:03 PM
Several pointers for you: There is no general right for any motor vehicle to park on a public highway. A highway is for the purposes of passing and repassing, not parking on. There are exceptions for emergency services, road repairs & similar & when a local authority designates it as a parking place & or creates resident partking schemes. but then they do it after consultation and from what you say there is no way they would do that when actual obstructions are caused. Paying your 'vehicle tax' does not give any rights to park outside your own property. Every parked vehicle is therefore automatically causing an obstruction and when a nuisance is caused such as you describe it is an actual obstruction. You appear to have a cast iron case against her. I would advise you against excessively sounding your car horn as it will wrong foot you as far as the authorities are concerned and is likely to be illegal and also loose you sympathy from your other neighbours. Take photos, measure the road width, collect your evidence. Ask the police and if they will not take action, initially a word in her ear from them should be sufficient, ask to see the dutry officer at your station politely but firmly explaining that if they will not take action you will make a formal complaint. That should sort it. If it still doesn't work write her a polite but firm letter, keep copies, send it recorded and warn her you will apply for a summons yourself at the Magistrates Court. Take your evidence to the Court and they will tell you how to swear out the information and that will result in the summons being sent to her. If the facts are as you state you can not loose. You can represent yourself and when you give your evidence you can appear concillatory by explaining your actions are a last resort and that even at this late stage if she will agree not to cause further obstructions you would be content for the court to bind her over rather than impose a fine.
Edit: Your own edit about her having her own drive way has considerably strengthened your case and demonstrates she is being awkward, it will damm her even further at court.
Taken from another wedsite.
