Aftermarket Penel Stock Primer...
Posted 04 September 2008 - 02:26 PM
Posted 04 September 2008 - 05:14 PM
The stuff that sticks well and doesnt come off with thinners is okay. It needs keying for primer though. I tend to use 320 on a DA (or by hand if you can be bothered!) then a red scotch brite for all the nooks and crannys.
Dont worry if you rub through to bare metal anywhere, but ideally its wise to etch prime any bare areas. Etch shouldnt need rubbing down or messing with before being surfaced primed.
Hope that helps.
Posted 04 September 2008 - 05:47 PM
Cheers jackSome of it will wipe off with thinners, thats the stuff you need to totally strip off otherwise you can get problems later on.
Hope that helps.
...still not sprayed this bloody car lol
