BEEP BEEP!
8 replies to this topic
#1 miniman5
miniman5
    1 Gold star
  • 3,135 posts
Posted 30 June 2005 - 07:53 AM
hello, i recently re-wired my air horns, and i was wondering, does the horn need to work weather the iggnitions on or not??
#2 Dom
Dom
    Moved Into The Mazda
  • 10,685 posts
Posted 30 June 2005 - 08:47 AM
do you mean to pass the mot?
i dont think air horns pass on mot if they're hooked up to the main horn to replace it but if you had them on another switch you'd be ok.
#3 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 30 June 2005 - 08:52 AM
As long as they are single tone the yes they will be OK for MOT, and yes they need to work at all times, ignition on or off, but if you leave you existing horn in aswell, and then feed the air horns from the ignition loom with an isolating switch, you can witch them off when you come to MOT anyway
#4 clubman katie B.F
clubman katie B.F
  • 1,524 posts
Posted 30 June 2005 - 01:29 PM
one of the mini mags mentioned in this months issue that air horns are legal for pre 1973 cars. after that they are only for "show" use
#5 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 30 June 2005 - 02:10 PM
I thinks that's multi tone horns ( like the Dukes of Hazard ones )
#6 minimadmansam
minimadmansam
  • 62 posts
  • Local Club: Rusty Nuts Mini Club
Posted 01 July 2005 - 02:15 PM
normal horns work without the ignition on, i don't know about air horns tho, my brothers mini has them and drives around in it making funny noises and looking like a complete and utter tw_t.
#7 Teapot
Teapot
    TMF Legend
  • 5,010 posts
Posted 01 July 2005 - 04:10 PM
My ordinary beep-beep and the twin airhorns can be switched from the steering column. I forgot to switch back to beep-beep for the MOT, but nobody said anything, so ... was I just lucky?
#8 marc
marc
  • 2,138 posts
Posted 01 July 2005 - 04:50 PM
I'm sure you can have air horns for an mot as long as they dont play tunes, so just a single tone as said before. My mums range rover had them and it passed fine.
Dont know about wether they've got to work with the ignition off but most car horns do work with the ignition off so there must be a reason for it.
#9 binge
binge
  • 2,508 posts
Posted 02 July 2005 - 11:26 AM
Just keep your origional horn. And then wire the air horns on a seperate loom with another switch...
Im after some air horns to play the Italian Job theme. Ive worked out the notes and everything, I Just need to find a compressor to play the damn choon...
<|Ben|>
