Is This Carb Missing A Pipe?
14 replies to this topic
#1 Kam
Kam
    Straight to the Point
  • 4,140 posts
  • Local Club: 16vMini club
Posted 06 September 2008 - 06:59 PM
My engines out so I cant compare as I've also got the same Hif38 carb, but I swear it had all three pipes hooked up?
This is from my mates clubby,
Its a Hif38 stage one on a 1098 clubman, it runs but I reckon its well underpowered, on mine I'm sure all three pipes were connected.
On above is the left one the fuel feed and right one bypass? So whats the one thats not connected top left?
>_<
#2 stormintrooper
stormintrooper
  • 2,072 posts
Posted 06 September 2008 - 07:02 PM
not familiar with hif's but my guess is an overflow pipe?
i have one on my HS4 next to the inlet pipe
#3 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 06 September 2008 - 07:06 PM
This is a recent picture of my Minis HIF44 carb and I believe the one you have missing is for the crankcase breather?: -
The one I'm pressing my finger down on (because mine's split) is for the fuel over-flow pipe.
Edited by taffy1967, 06 September 2008 - 07:08 PM.
#4 stormintrooper
stormintrooper
  • 2,072 posts
Posted 06 September 2008 - 07:07 PM
taffys sounds more right to me >_<
especialy if u think uv lost power
#5 Kam
Kam
  • 4,140 posts
Posted 06 September 2008 - 07:19 PM
There is only two large pipes attached, The same one your pressing is the one thats not on there, this dont sound good!
If its the fuel over flow so that means that fuel is peeing out on the bay?
>_<
#6 yorkshirechris
yorkshirechris
    11.11.11
  • 3,873 posts
  • Local Club: www.lcmoc.com
Posted 06 September 2008 - 07:20 PM
Well the overflow (if thats what it is) is only used to palm off excess fuel which there shouldn't be normally?
#7 Grayedout
Grayedout
  • 901 posts
Posted 06 September 2008 - 07:23 PM
It's the fuel overflow you are missing. Won't affect your performance but needs connecting as a safety feature and piping to the floor away from the hot exhaust.
Has the engine been fully serviced and set up ? If not then thats probably why it is not running as it should.
#8 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 06 September 2008 - 07:28 PM
Well I might be wrong, but it looks like your fuel overpipe is connected. it's the one connected to the metal pipe?
I'd say it's the breather pipe that runs to the crankcase breather that's missing from your carb.
#9 Kam
Kam
  • 4,140 posts
Posted 06 September 2008 - 07:41 PM
It does need to go on the rollers but came across this whilst being nosey.
The lower one that is connected in the metal pipe is the fuel feed, the one directly above aint, so over flow sounds right.
The crank breather is also connected thats the larger one at the bottom of the pic.
#10 mini_kel
mini_kel
  • 2,851 posts
  • Local Club: EMC/No pub mini club
Posted 06 September 2008 - 07:55 PM
The one not connected in the picture is overflow pipe
#11 Sleepy Stu
Sleepy Stu
    formerly Stewart_GT
  • 2,564 posts
Posted 06 September 2008 - 08:18 PM
Yep as mini_kel says in the very first pic the one not connected is indeed the fuel overflow pipe!
#12 stormintrooper
stormintrooper
  • 2,072 posts
Posted 06 September 2008 - 08:35 PM
wow i only made a gues an i might have been right :gimme:
#13 mini_kel
mini_kel
  • 2,851 posts
Posted 06 September 2008 - 08:40 PM
It wouldn`t explain why he has lost power though
#14 stormintrooper
stormintrooper
  • 2,072 posts
Posted 06 September 2008 - 08:47 PM
hence why i said might lol, as i said alot earlier tho, taffy's idea sound more reasonable to me
#15 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 06 September 2008 - 10:54 PM
So try blocking it with something and then see how it runs?
If it improves, then it's probably for the breather pipe.
