Transfer Case Breather
Posted 09 September 2008 - 12:31 AM
Posted 09 September 2008 - 12:52 AM
Posted 09 September 2008 - 01:03 AM
Posted 09 September 2008 - 01:24 AM
Posted 09 September 2008 - 01:52 AM
Posted 09 September 2008 - 02:02 AM
it is a brether but on an angle. unfortunately no pic on there.
Posted 09 September 2008 - 02:04 AM
Here is a straight one: http://www.7ent.com/....cfm?pageid=470
Here is teh one you need: http://www.7ent.com/....cfm?pageid=471
Posted 09 September 2008 - 02:09 AM
Thats what im talking about Many thanks MinibooFound a pic orr 2.
Posted 09 September 2008 - 08:17 AM
Posted 09 September 2008 - 09:57 AM
that is also a good idea. I must be getting lazy and old because i just opt for the easy option but i think the brazing rods are coming out and you have just won the idea of the month awardOr you could cut and reweld the short pipe under the main canister at a different angle?
Posted 09 September 2008 - 11:49 AM
Posted 09 September 2008 - 03:40 PM
Posted 09 September 2008 - 04:23 PM
Ooopsy! I've only got one of mine connected to the carb and my fueling is all screwed up. I'll fix it and let you know if anything changes.If you have one end of the pcv system connected up properly to the carb and the other end venting to atmosphere like this you will destroy the fuelling and the accuracy of the metering system in the carb. Either all the usual ports must be connected to the carb and the crankcase breathing throug the oil cap as it's meant to or it should all be disconnected completely and breathing to atmosphere with the carb inlet sealed. Connecting it up properly is by far the better option for a road car.
Posted 05 October 2008 - 05:02 AM
If this tapped hole is a common type, does anyone know what type of thread and or size, or if there would be issues if I were to just plug it with a bolt since I have a vent off the rocker cover?
Edited by scootdaboot, 05 October 2008 - 05:18 AM.
