Seam Sealer Cracking?
10 replies to this topic
#1 monkee-face
monkee-face
  • 243 posts
Posted 10 September 2008 - 08:56 PM
im retroing a mini van 1979 (1 of 12 minis lucky me :P )... in need of a couple of sills and a d/s floor.... im using tetrosyl seam sealer.......and to my mind its not alot of good.... it always seams to crak when its dries?
anyone had thos problem before?
maby a different type is in order ?
any suggestion welcome
;) :P
#2 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 10 September 2008 - 08:59 PM
If i was you i would defonately try a different brand as its not going to be doing its job if its cracking, in its dry state it should still have a flax in it, so if its cracking then its not going to be doing its job and will just trap water...
Edited by Tomf, 10 September 2008 - 09:00 PM.
#3 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 10 September 2008 - 10:08 PM
Try 'Silkaflex' or 'Tigerseal'
You can also get it for brush application that comes in a paint tin.
#4 1984mini25
1984mini25
  • 8,784 posts
Posted 10 September 2008 - 10:14 PM
The brushable Grey stripe seam sealer does the same :P
#5 Scott.Tamson
Scott.Tamson
  • 750 posts
  • Local Club: None..on here alottt though :)
Posted 10 September 2008 - 11:24 PM
I had this problem with seam sealer.. the same make as your using. It appeared as if it was reacting to the primer as we tried it on a bit that hadnt been primed and seamed to be fine.
EDIT = Haha, jus noticed what i done :shifty: Seamed to be fine
Edited by Scott.Tamson, 10 September 2008 - 11:25 PM.
#6 kirk
kirk
  • 143 posts
Posted 11 September 2008 - 06:59 AM
carnt beat tiger seal nearly 8 quid a tube but its the best you can buy
and does the job very well and is also over paintable
#7 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 11 September 2008 - 09:05 PM
No seam sealer should crack, even the cheap stuff. You must be doing something wrong or using non compatible materials. Always make sure any coatings under where it is applied are completely dry, and that the sealer is dry before you paint over it.
#8 MiniMick
MiniMick
  • 508 posts
Posted 11 September 2008 - 09:14 PM
I bet it was dum dum sealer that was used as it's rubish, use a brushable never had any problems with that
#9 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 11 September 2008 - 10:51 PM
Dum dum isn't rubbish!!! One of the best things ever invented! If anyone uses it as seam sealer though, they are just stupid.
#10 monkee-face
monkee-face
  • 243 posts
Posted 12 September 2008 - 12:52 PM
thanks for all your replys! i will definatly go out and spend a small fourtune on some proper stuff...........:) it had to be that make. i did have mirka? stuff before and that never craked.....
oh welll never mind......
also ill post up some pic's of the resto work carryed out so far in the projects section later on( ive got loads of photos)
#11 monkee-face
monkee-face
  • 243 posts
Posted 12 September 2008 - 08:58 PM
ive just found a site call frost... they do a dintrol sema sealer in a tube.
anyone used this ?
