Posted 26 March 2010 - 09:42 PM
actually, i'm interested in mating a complete bike engine with a mini gearbox as well. and i've spent hours/days on here looking for someone that's done it.
my logic tells me that if i connect say a 100hp bike engine to the mini flywheel/clutch, you would still have a reliable engine conversion without the need for costly subframes/diffs etc. AND have a reverse gear.
have a thick plate of sorts blocking off the top of the gearbox(and switch to trans fluid), connect the engine of choice to the flywheel/ clutch(some sort of machined adapter would probably be required) and bob's your uncle.
correct me if i'm wrong plz, i only got my mini 2 weeks ago, but i'm fairly mechanically inclined(mainly bikes) and this makes sense to me.
technically the mini would then have 2 gearboxes, but only the mini one would be in use.
the bike engine's strongest torque gear(1st would be used permanently.)
this application would be ideal for older model engines that are affordable like the suzuki TL1000 or the air/oil cooled bandit 1200(that would simplify A LOT with regards to cooling etc). i mention these engines due to their hp value of around 100hp( i hear the mini gearbox is good for up to 100hp) and they both have high torque outputs.
