Carb Identification.
3 replies to this topic
#1 rachsmini
rachsmini
  • 51 posts
Posted 13 September 2008 - 10:59 PM
~~~~~Please delete this text before posting the topic~~~~~~
Please give your topic a title that quickly describes your problem. Just putting 'Help my Mini doesn't work' is useless to anyone trying to help.
Model:
Year:
Any non-standard parts that might be involved with the problem?
hello all, i recently purchased a 1994 mayfair 1275, the carb needs new jets and needles, thats whats recommended on the last service. my question to you all is what type of a carb will mine be, also its currrently running with a lcb, so what would be my best carb to suit this? could i get one from the local breakers of another rover or something, strip it and service it myself before fitting it.
cheers rach
#2 Ethel
  • 26,170 posts
Posted 14 September 2008 - 12:34 AM
I think it'll be a Hif44. SU's are very simple and can go on for ever.
There's a Haynes Manual just for SU Carb's, wouldn't be surprised if your local library has a copy if you ask also masses of info online.
http://www.youtube.c...feature=related check out his other SU vids too
#3 lrostoke
lrostoke
  • 6,923 posts
Posted 14 September 2008 - 07:35 AM
Mini Cooper, 1275 cc, (12A) 1990-on
Carburettor type . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . SU HIF44
Piston spring . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Red
Jet size . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.5 mm
Needle . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . BFY
Idle mixture CO % . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.6 to 3.0 (measured
Idle speed . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 900 rpm
Fast idle speed . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1200 ± 50 rpm
Mini Saloon and variants, 1275 cc (12A) 1992-on
Carburettor type . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . SU HIF38
According to Haynes they actually changed from a HIF44 to a HIF38 from 1992 on ??..Actually rereading that it seems to read like the Cooper 1275's had the 44, and the other 1275 variants the 38 !!
I've no real experience with the HIF's so not sure what identification marks they have, I do know the throttle aperture is 44mm on the HIF44, and 38mm on the HIF38.
Edited by lrostoke, 14 September 2008 - 07:39 AM.
#4 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 14 September 2008 - 11:27 AM
Yes the early Rover Mini Coopers were the only models to get the HIF44 carburettor before going fuel injection in October 1991.
The post 1992 non-Cooper models (Sprite, Mayfair and a host of LE's) got the HIF38, before switching to fuel injection some time in 1995 (I believe?)
