Perished Crank Damper Pulley...
9 replies to this topic
#1 adcyork
adcyork
  • 490 posts
Posted 14 September 2008 - 02:10 PM
I've got an MG metro 1275 i'm stripping down and rebuilding and i've found that the elastomer in the crank damper pulley is perished and well past its' sell by date so i'm going to need a replacment.
So i've been looking around and i can't find the standard type on sale anywhere.
I can only seem to find higher qualityversions from companies such as MED, Swiftune but they're about £100 odd, so where do i get one?
#2 mk1leg
mk1leg
  • 9,343 posts
Posted 14 September 2008 - 06:01 PM
there a better quality damper so use them and you will sleep better................ :turtle:
#3 HARBER07
HARBER07
  • 4,498 posts
  • Local Club: Naaa......
Posted 14 September 2008 - 06:15 PM
Whats the idea of these crank dampers then?
#4 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 14 September 2008 - 07:00 PM
To absorb and control harmonic vibrations in the crank and prevent it snapping.
The standard A+ crank damper is perfectly adequate, if you can find one.
#5 HARBER07
HARBER07
  • 4,498 posts
Posted 14 September 2008 - 07:09 PM
Thanks Dan, So its a good idea to have one? I have just a pulley on mine at the moment. Sorry for hijacking (keeps it up top anyway)
#6 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 14 September 2008 - 07:16 PM
It's such a good idea that all multi cylinder engines have one!
The standard pulley is a damper pulley.
#7 Ethel
  • 25,996 posts
Posted 14 September 2008 - 07:19 PM
Austin Rover never saw the need to put a damper on the small bore A. Don't worry unless your churning over at 4-5k revs for hours on end.
#8 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 14 September 2008 - 07:25 PM
Errm, yes they did. ALL A series engines need a crank damper because of the three main bearing crank, engine size isn't relevant. 998s had a damper pulley just the same as 1275s.
The A+ pulley is actually pretty good as I said above.
Edited by Dan, 14 September 2008 - 07:25 PM.
#9 Ethel
  • 25,996 posts
Posted 14 September 2008 - 07:41 PM
I'm sure I've owned many a small bore A with a plain crank pulley. The fan belt and water pump will do the damping job to some degree. Having only 3 mains makes the A Series crank nice 'n short and torsionally stiffer - admittedly it can wobble about in other directions more than a 5 bearing lump.
#10 adcyork
adcyork
  • 490 posts
Posted 14 September 2008 - 08:14 PM
I would do if my wallet would allow me to :kiss:
I have just a minute ago found and bought a pulley on ebay. I've been looking for the last 3 months and now i bother to post on here about alternatives, a pulley turns up on ebay. Sods law isn't it >_<
Thanks guys
Edited by adcyork, 14 September 2008 - 08:14 PM.
