Converting From Spi To Downdraught Weber
10 replies to this topic
#1 superted87
superted87
  • 754 posts
Posted 18 September 2008 - 12:51 PM
Hi guys
What would i need to do to change from a standard spi set up with MEMS and everything standard to a downdraught weber 26/32 (i think it is). The car is a 1995 sprite.
I am maybe thinking of megajolting it too so i might just ditch the ECU and get a Jolt Jr and weber . What do you reckon guys??
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 18 September 2008 - 04:53 PM
do you need this car to pass a MOT emissions test ?
#3 superted87
superted87
  • 754 posts
Posted 18 September 2008 - 08:36 PM
No because i had the engine made up from an older engine with the modern spi gear from the original car.
Would i be in serious doo doo then or are webers renound for being a bit thirsty??
#4 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 18 September 2008 - 09:16 PM
thirsty
a HIF44 would do a better job
#5 superted87
superted87
  • 754 posts
Posted 19 September 2008 - 10:10 AM
i have a 1330, 296 cam, x pin diff, 1.5 rollers and i am going megajolt so back to my original question, what do i need to change it from injection to a weber downdraught.?????????
#6 datsun100a
datsun100a
  • 338 posts
  • Local Club: www.mini-chat.co.uk
Posted 22 September 2008 - 06:49 AM
what sort of fuel pump are you using? This is a very easy and worthwhile conversion.
If you set it up correctly, emissions won't be a problem either.
Edited by datsun100a, 22 September 2008 - 08:04 AM.
#7 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 22 September 2008 - 07:31 AM
Personally, I'd rate the HIF44 way over the downdraft weber ( unless it's an IDA of course )
ps, only if you can prove the age of the engine will it affect the 'MOT year' and hence emissions.
#8 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 22 September 2008 - 07:34 AM
But in answer to the question, ditch the ignition/injection system in it's entirey, ecu etc etc, replace the dizzy for a 'normal' one or mappable ignition ( eg megajolt ) and off you go...
#9 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 22 September 2008 - 11:57 AM
I have a 28/36 Downdraught weber available if anyone is interested.
#10 datsun100a
datsun100a
  • 338 posts
Posted 22 September 2008 - 12:21 PM
Is it complete, price?
#11 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 22 September 2008 - 03:45 PM
Hello
It is a complete Weber 28/36 DCD carb and inlet manifold for A-series Mini engines.
Pics and price here http://www.theminifo...p;#entry1141923
Price negotiable, but ive knocked back alot of silly offers so please dont take the *yellow human water*.
Jordie
