Headlamp plastic bowl thingys
2 replies to this topic
#1 northern_monkey
northern_monkey
  • 68 posts
Posted 05 July 2005 - 08:33 AM
Just a quick Q:
After you remove the headlamp form the mini with the retaining spring and disconnect the bulbs/wires you're left with the plastic bowl bit sat attached to the front wings.
It appears to be rivetted on - is this right, just a case of drilling out the rivets to remove and if so how do people re-attach them?
Self tappers, or rivet back on.
If it needs rivetting, what sort of rivetting gun/tool do I need as its not something I've ever used before.
#2 Pooky
Pooky
  • 5,691 posts
Posted 05 July 2005 - 08:54 AM
I just put some small bolts back through mine! Easy! :rolleyes:
I suppose you could use a pop riveter!? :w00t:
#3 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 05 July 2005 - 09:23 AM
Yeh, on the later minis they riveted the bowls on, but can be replaced with a self tapper and those spring type clips on the back for the screw to go through
