92 cooper spi
on the front drivetrain you have the shaft that leads up to the brake disk's....before it goes through there...there is a rubber cone of some sort is it called the c.v joint...
asking becauseits torn and needs replacing
Front Drivetrain
cooperdan
, Sep 21 2008 04:03 PM
3 replies to this topic
Posted 21 September 2008 - 04:03 PM
Posted 21 September 2008 - 04:21 PM
yes it is called a cv joint easy to replace the boot if you have the right tools ie.splitter,socket,for the large nut on the end of the driveshaft ect
Posted 21 September 2008 - 04:28 PM
thanks jonny
Posted 22 September 2008 - 03:21 PM
when i replace the rubber boot on the drivetrain...when i reconnect the arm and etc will it not put my tracking out...?
