Engine Stabiliser
2 replies to this topic
#1 rachsmini
rachsmini
  • 51 posts
Posted 21 September 2008 - 09:58 PM
~~~~~Please delete this text before posting the topic~~~~~~
Please give your topic a title that quickly describes your problem. Just putting 'Help my Mini doesn't work' is useless to anyone trying to help.
Model:
Year:
Any non-standard parts that might be involved with the problem?
hello, brought a job lot of few mini spares, there is a engine stabiliser in there, has anyone got a picture of where its fitted please as i want to fit it.
cheers rach..
#2 just_st3v3n
just_st3v3n
  • 90 posts
Posted 21 September 2008 - 10:32 PM
i dont have any pics but if you open the bonnet and look at the top left hand side of the engine there is a stabilizer there, think theres one or two at the bottom back of the engine too... not to sure but someone will be able to help out...
try do a search for it and have a look trough the project minis you may find it there..
steven
#3 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 22 September 2008 - 09:01 AM
From factory there were two stabilisers fitted.
One is at the back of the engine at the top. Attatched at one end to the mounting plate underneath the brake and clutch cylinders,.. the other end attaches to the cylinder head along with a bracket and sometimes an earth strap.
The other Engine stabiliser attaches to the subframe front and bolts up to the Gearbox Case via a small bracket on the left or right hand side of the engine (drivers side is much more common to find) Look at the sump plug and you'll see the engine steady in the area above it.
There are aftermarket steadies available such as the Adjustable steady from KAD (lovely piece of kit) and the Ultimate Engine steadies (that rip your bulkhead open) :P
