After going through the new Mini Sport catalog I picked out the following kits:
SUSPENSION:
SUSCKIT02 Full Kit with GAZ 36pt shock absorbers 274.92
Comes with mini sport adjusta ride kit, adjustable tie rods, negative camber arms, negative camber and tracking rear brackets, lower arm poly bushes, tie rod poly bushes, and shock absorbers.
BRAKES:
MSLMS01 Full Kit - with 7.9" vented grooved discs 316.25
Comes with calipers, brake discs, brake pads, pad pins, and all necessary fittings
My questions:
1) Do these kits seem good enough to give me some decent handling after I change out my 998cc for something bigger (e.g. 1275cc or higher)?
2) Would you recommend I do anything else to improve the handling (e.g. reinforce the rear subframe...etc)? I'm sure wider tires would help but I'm trying to keep everything visible as stock looking as possible.
Thanks in advance for any advice!
