How To Remove Stubborn Ball Joints
6 replies to this topic
#1 minifan08
minifan08
  • 71 posts
Posted 24 September 2008 - 03:36 PM
hi iv just started to strip down my 1990 mini city, when i came to remove the top ball joint on the passenger side swivel hub i use the ball joint splitter (scissor type) as normal i tightened it up and waited for the bang when it came it was not the ball joint but the splitter end snapping clean off :D . i was just wondering if i was doing anything wrong and a few tips would help.
thanks chris
#2 Ethel
  • 26,022 posts
Posted 24 September 2008 - 03:49 PM
Probably just a duff splitter. Shouldn't be able to break one without using a mega big bar to wind it up.
#3 minifan08
minifan08
  • 71 posts
Posted 24 September 2008 - 03:51 PM
quite possibly cus it was only a normal ring spanner
#4 pantera2075
pantera2075
  • 596 posts
  • Local Club: GTMOC
Posted 24 September 2008 - 04:00 PM
Cheap splitters will do this with regularity. I always now use the "fork and belt it one" type, but they do goose the rubbers more readily.
#5 Sleepy Stu
Sleepy Stu
    formerly Stewart_GT
  • 2,564 posts
Posted 24 September 2008 - 05:58 PM
Im with Pantera. Usually i can free them with a mighty big blow from a lump hammer however the fork is also very good. As stated though it does screw the rubbers!! :D
#6 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 24 September 2008 - 06:33 PM
As stated above, tighten the splitter until it seems ridiculously tight, then bring out the big hammer and give the splitter's bolt a strong blow (like driving a nail) to shock the joint. Don't count on the force alone to unseat the tapered parts.
#7 wile e coyote
wile e coyote
  • 1,230 posts
Posted 24 September 2008 - 08:29 PM
Yep probably just a duff splitter.. helps to leave the nut on the thread at the top of the shank to spread the load a bit, after removing completely & greasing first (to make sure you can eaily get it off again after the taper is free) I've got a cheapo Clarke one I've had for ages without any probs - a bit of copperslip in the taper before reassembly will prevent reoccurence though....having said that nothing is as satisfying as lump hammer on a fork splitter - machine mart have a set with 3 interchangable fork sizes that should minmise risk of completely bu^^ering rubbers for about 15 quid
