as above really my sprite failed its MOT today. quite peeved off really i thort id done everything that needed doing and was proven very wrong. the car has been off the road now for about 2-3 months and was looking forward to driving to work tomorrow to stop my work "mates" mocking me and my mini. from what he was saying on the phone it sounds like theres quite a lot of work thats needed.
he said,
both upper ball joints were worn, even though they and the lower ones were replaced while its been off the road.
both track rod ends are loose. once again i replaced these and double checked the nuts on top were tights as im mega paranoid.
rear breaks and hand break doing very little. i changed and adjusted the the rear shoes to what i thought was gud, and they worked better than they did before i changed them.
fuel leek at the carb. im really worried about that as it wasnt leeking when i had it running on sunday and i have new carbs and fuel pipes.
head lamps not working properly. when i turned them on just before going to the mot they came on , both side lights and dipped and full beam, so im not sure if he means the angle they are pointing at till i go see him tomorrow.
and then which made me really annoyed he said there was no front shock absorber, which was true, but when i booked it in on friday i told them that the lower mounting bolt had snapped and needed heating up to get out they said yes they would get that out for me when i took it in and then MOT it. Both the new bolt, and shock absorber were on the front driver seat when i left it with them. and when i explained what was said when i booked it in he said he didnt no that he was suppozed to replace the shock absorber bolt.
and then he went on to say if you come in tomorrow we can give you a quote to fix everything. but i want to check everything before i take his word for it and end up paying a few hundered quid for them to fix everything.
the reason i took it to this garage was because the one i used to take my mini to went out of business. also this new one there has quite often been minis parked on the front.
one last thing, is it legal for me to drive it home so i can check everything?
cheers, phil
Edited by phil_clubman, 30 September 2008 - 01:42 AM.
