Oil Cooler!?!
6 replies to this topic
#1 chris_gilly
chris_gilly
  • 571 posts
Posted 30 September 2008 - 05:01 PM
Model: city
Year: 1989
right i was thinking of fitting an oil cooler! and just want to know a few things!!
any help will be great!!
what are the benefits of fitting one??
where can i get one from and how much are they???
when do you NEED to fit one?
#2 mike.
mike.
  • 6,176 posts
Posted 30 September 2008 - 05:08 PM
The benifits on a standard engine are none - Infact the engine oil might get overcooled and never get up to temperature.
There about £35 plus another £30 off for the hoses and most mini places sell them - Minisport, minispares etc
You only really need to fit one on highly tuned engines or engines that tend to get very hot - Such as a turbo or race engine. Its also advised that one is fitted ifd you fit a sump guard as sump guards greatly reduces airflow around the sump and its cooling fins.
Bottom line basically - They're pretty unnessesary in alot of cases.
Edited by minimadmike, 30 September 2008 - 05:09 PM.
#3 chris_gilly
chris_gilly
  • 571 posts
Posted 30 September 2008 - 05:10 PM
ok cheers matey :thumbsup:
#4 Monstrous
Monstrous
  • 889 posts
Posted 30 September 2008 - 05:13 PM
It has been recommended that if you do fit one, that you should fit some form of oil thermostat inline with it, meaning the oil will only flow through the cooler if it exceeds a set temperature as like Mike said, you may risk cooling the oil down too much on a standard engine
#5 1987_ParkLane
1987_ParkLane
  • 2,671 posts
  • Local Club: The Mini Forum
Posted 30 September 2008 - 05:15 PM
Also could you use them oil flushers when you fit one? As I use them when I change my oil to get all the cr*p out and stuff, so just wondering if they would ruin it?
#6 mike.
mike.
  • 6,176 posts
Posted 30 September 2008 - 05:19 PM
Once an oil coolers got any *rubbish* in it, it won't come out. They're very hard to clean out properly. I wouldn't advice using those engine flush additives if you have one fitted.
However its only a 10 min job to take the cooler off and refit the standard oil pipe if you were doing an oil change and wanted to flush the engine through.
#7 THE ANORAK
THE ANORAK
  • 3,946 posts
Posted 30 September 2008 - 05:25 PM
a point to note: the RSP limited edition cooper (the car that launched the return of the cooper) had an oil cooler fitted as standard but by the time the car got to mainstream production it had gone !!!!
why ???
i didnt need it :thumbsup:
