replacement Battery??
11 replies to this topic
#1 ace
ace
  • 140 posts
  • Local Club: Posh Mini Owners Club
Posted 01 October 2008 - 10:24 AM
quick one - might need a new battery and I'm looking to put a bit of Ice in the mini
I believe (did search) that people put PUG 306 diesel batteries in as they are much bettery than standard - is this correct????
Edited by ace, 01 October 2008 - 10:28 AM.
#2 analogue_radio
analogue_radio
  • 4,897 posts
Posted 01 October 2008 - 10:27 AM
:thumbsup:
#3 wolfys_mini
wolfys_mini
  • 2,493 posts
  • Local Club: many!
Posted 01 October 2008 - 10:29 AM
yes it is
#4 ace
ace
  • 140 posts
Posted 01 October 2008 - 10:38 AM
sorry about the title of thread - multi tasking on internet :thumbsup: , its not relivant to post.
thans for the advice on the battery!!
Edited by ace, 01 October 2008 - 10:39 AM.
#5 JohnGordon
JohnGordon
  • 966 posts
  • Local Club: N.W Mini's / O.D.M.C
Posted 01 October 2008 - 10:43 AM
Yep put a 306 TD battery on
#6 ace
ace
  • 140 posts
Posted 01 October 2008 - 10:44 AM
halford want £89.99 / £99.99 how about the one below??
http://www.performan...rs#battery_info
#7 Ouster
Ouster
  • 2,986 posts
  • Local Club: Looking
Posted 01 October 2008 - 10:47 AM
How much is "a bit of ice"? If it's a lot, you'll need to upgrade the alternator and may need a yellow top battery instead.
If you can get a trade card at Halfords (turn up with a load of motorfactors receipts) then the battery will drop to around £30.
#8 JohnGordon
JohnGordon
  • 966 posts
motor factors down the road £30?
#9 998dave
998dave
    998cc's Of Dave Goodness
  • 4,566 posts
  • Name: Dave
Posted 01 October 2008 - 11:21 AM
Do they really drop that much, useful to know if they do!
Dave
#10 ace
ace
  • 140 posts
Posted 01 October 2008 - 11:32 AM
found the battery model number that looks the best bet - 075 battery - got a quote from my local parts - they what £49.99 not too bad I think.
#11 millermilla
millermilla
  • 452 posts
  • Local Club: BMC Brighton Mini Club
Posted 01 October 2008 - 01:36 PM
You can fit an 063, 065, 075 or 027 in a mini battery tray with the 027 being the most powerfull of the lot at around 540CCA which is more than double the original battery. You may find you have to adjust the clamp a fair bit to get an 027 to fit and the spare wheel is a bit of a squeeze to get in / out. I have a Halfords trade card and you get about 40% off batteries. Regarding battery prices you generally get what you pay for i.e a £99 3 yr gaurantee battery from Halfords will be much better quality and outlast a £49 1 yr battery from a motor factor.
#12 Ethel
  • 26,074 posts
Posted 01 October 2008 - 02:03 PM
Not sure what advantage you'd see from fitting a high power battery to a mini, warmer battery cables? :thumbsup:
A higher capacity battery will help if you intend sitting in your car, trying to burst your eardrums, for extended periods without the engine running. You really need a bigger alternator if you want to use more amps than your current one makes.
