I despertaly want a ratio gauge for my mini, but im not sure how they sense? is it a lambda sensor if it is I can easily put on of these in my exhaust system, but I have been told it uses the mass air flow sensor on an injection car, I have no idea. Can someone shed some light if theyve fitted one.
Air/ Fuel Ratio Gauge
mini_mad69
, Oct 01 2008 04:20 PM
5 replies to this topic
Posted 01 October 2008 - 04:20 PM
Posted 01 October 2008 - 04:54 PM
It reads off of the Lambda probe
Posted 01 October 2008 - 04:57 PM
Oh ok, brilliant thanks for the reply, what sort do you think I will need because there are a couple of lambda probres out there, 2,3 or 4 wire?
Oh i was looking into getting a shift light aswell, but there 22 quid, does anyone know how these are wired aswell, because I dont want to buy one and not be able to wire it in because i dont have a ecu. Im quite handy with car electrics but mostly alarms and sound system.
Edited by mini_mad69, 01 October 2008 - 05:04 PM.
Posted 01 October 2008 - 05:25 PM
Get a 4 wire lambda and yes a shift light can be wired in
Posted 01 October 2008 - 05:26 PM
Brilliant thanks alot for your help, ill order the bits to put it all together now.
Posted 02 October 2008 - 09:01 AM
Just a some of those lambda mixture gauges are narrow band intended for injection cars and only work on idle/light throtal, could consider wide band!
