Centre Oil Pick Up Pipe
9 replies to this topic
#1 MINI 1
MINI 1
    The Ginger One #2
  • 714 posts
  • Local Club: LCMOC
Posted 02 October 2008 - 08:02 PM
hi , about to assembly my 1380 using a 998 gearbox , the gearbox will be kept standerd but i am thinking about a Centre oil pick up pipe. Are these worth fitting ? and do they just go in without removing the gears?
cheers
ash
#2 Broomer
Broomer
  • 1,771 posts
Posted 02 October 2008 - 08:04 PM
Definately worth fitting, would be silly not to with a new engine. many a time i got my oil preassure to drop drastically in my gearbox without a centre oil pickup. starved the cylinders of oil, you get the jist..
#3 MINI 1
MINI 1
    The Ginger One #2
  • 714 posts
  • Local Club: LCMOC
Posted 02 October 2008 - 08:20 PM
how easy are they to fit? can they be done at home... what i mean is do they have to be fitted when all gears are out.
ash
#4 CMcB
CMcB
  • 999 posts
Im no expert, but yes they are worth fitting as it more evenly distributes oil in the gearbox - i believe.
#5 IvanTheMini
IvanTheMini
  • 42 posts
  • Local Club: Tarheel Mini Motoring
Posted 02 October 2008 - 08:36 PM
a royal pain to install though, or at least to get the old one out.
#6 Sam Walters
Sam Walters
  • 2,765 posts
Posted 02 October 2008 - 08:39 PM
They go in with one of the gear blocks.
one locks the other in kind of thing.
#7 998dave
998dave
    998cc's Of Dave Goodness
  • 4,566 posts
  • Name: Dave
Posted 03 October 2008 - 07:22 AM
Not too bad to fit, it's easiest to drift out the laygear, fit the filter, and clean the sump out while you're there, then put the shaft back in, at most a 30 minute job, and worth every penny and minute when building a new engine.
Dave
Edit: Thanks for the word I was after Jammy...
Edited by 998dave, 03 October 2008 - 09:52 AM.
#8 Jammy
Jammy
  • 25,397 posts
Posted 03 October 2008 - 07:47 AM
It doesn't require removal of the mainshaft (which is the hard part of assembling the gearbox, just the laygear has to come out, which is relatively easy.
#9 1987_ParkLane
1987_ParkLane
  • 2,671 posts
  • Local Club: The Mini Forum
Posted 03 October 2008 - 09:52 AM
Would a standard 998 engine be strong enough?
#10 998dave
998dave
  • 4,566 posts
  • Name: Dave
Posted 06 October 2008 - 07:48 AM
Standard 998 gerbox you mean?
Just as strong as a standard 1275 I guess... Should be okay for a while.
