i've left the arches as i will be tubbing them when the weather gets better,and seemed a waste to have to re-paint them,got most of the rear floorpan done just need to do the front.
i also decided to try my f/g bonnet for size
does'nt look to bad but im going to need to play with it a bit
i think once pin's are fitted and a little trimming i should be able to sort this,shame considering the other side is fine
hopefully get some pin's and strap's ordered for the bonnet,and a mate is getting me some brackets so i can start work on fitting the miglia arches
i got my front subframe out the shed and started building it up,got so far and im now stuck as i'll be using some bits which are still on FRK.
so far subby has got
(i'll add a pic later
- powdercoated in blue
-new cones
-adjusta ride's
-recon top arms
-new bump stop's
-subframe mounts on rear
-braided hoses for brakes
i would like to get a solid mounting kit from mini spares,and some 1.5 - camber lower arms and adj tie rods would be nice so need to earn some cash fast!.
