Project Frk- For Road & Track
#46
Posted 24 February 2009 - 03:39 PM
#47
Posted 24 February 2009 - 05:47 PM
i must say, without being rude, this isnt very stealth anymore..
i was thinking the same to be honest with the big wheels arches and f/g front but once it all comes together and i get the "secret" engine installed in the future with the paint job i've decided on im sure it'll look very stealthy
here's my engine bay now tis all naked except wiring loom
should get the inner wings cut back tomorrow and start prepping ready for paint
#48
Posted 01 March 2009 - 10:03 PM
started by removing passenger side shock mount to see what rust lurk's behind
think i got there just in time
next i got the grinder out and cut back the inner wings
it was then i decided to have a trial fit of the front from abs,i thought you had to pull steel panels alot to get a good fit *melon* me how i was suprised how much pulling twisting and sanding is needed for a f/g front let alone the swearing involved
i've got a dremel which i used to lightly trim the edges which have pleanty to play with from the mould,test fit then mark where to cut/sand remove panel swear at it again,bit more sanding swear a little more
go for cuppa come back little more cutting and sanding,test fit again and swear even more
give up for the afternoon as light went during the chat hopefully make some progress tomorrow with some more pic's
Edited by guywithvan, 01 March 2009 - 10:06 PM.
#49
Posted 01 March 2009 - 10:07 PM
#50
#51
Posted 01 March 2009 - 10:09 PM
lookin good u not got more pics ???
got a little distracted with the front,and a friendly chat about mini's with a young lad from up the road,i'll get some more tomorrow
#52
Posted 01 March 2009 - 10:11 PM
Pictures are waaaaay too small mate, can't see what's going on! & it looks as if I'm missing out on the good stuff!
small pic's due to *melon* camera phone and lack of money to afford shiny new digi camera
#53
Posted 01 July 2009 - 03:39 PM
so a few weeks back i borrowed a trailer off my uncle and got my mini's over to new place pretty shocked at the state of my van as it's been out of sight and outside for too long,oh i love creating more work for myself
anyway FRK is first on the list and i started on monday by jacking him up and removing the rear subby,suprisingly it came off very easy with no snapped bolts or serious corrosion underneath,i do love low milage autos
so the subby mounting panel looks good
i also decided to remove the rear valence to make it easier repairing a dent in the rear and possibly use a f/g or c/f one in the future
it's a bit rusty there but at the worst a very small patch
rest of the boot floor looks pretty good including the valence closing panels which considering are original have do really well
worst bit of rust is here,it's solid so i might get away with treating it or a small patch which would be a shame as the closing panel is in great condition
once the subby was off i've stripped it down and all parts will eventually get re furbished and used on my van,i have new parts for FRK and consist of the following
new rear subby
re-con radius arms
new back plate assembly's /mini fins
braided hoses
new cones / hi-lo's maybe change to min-tastic spring's later
so to keep me busy till i can paint the underside i started cleaning a few bits up
i stripped down some spare hubs and removed the bearings/wheel studs and gave them a good clean with wire brush then a lick of blue as it will be part of the colour coding on FRK.
i also removed my calipers a while back ready for rebuilding so i stripped them down getting the pistons out was easy using a technique mentioned on here,it's suprising what a grease gun can do
all cleaned up and couple coats of caliper paint i think they look pretty good,just a shame i cannot afford a decent camera to show you guy's better!!
next plans are to build the rear hubs up with new bearings/stud's i have stocked,then once i've flushed out the calipers they'll get some new seal's and maybe one piston needs changing.
other than the poor pic's im quite happy so far,got another few bit's to get painted up so im off for now
#54
Posted 02 July 2009 - 11:06 PM
started putting my radius arms together and new bearings in the hubs,realised i had'nt painted the bracket's for handbrake cable so had to do them before i could finish fitting the back plates.
so whilst paint was drying i gave the underside of the boot floor and wheel arches a good wire brushing
im more than likely going to roll FRK on his side and completly strip the floor and repaint/stonechip so i though i might aswell start getting ready for it
by dropping the front subby
to make things a bit lighter i removed hub's tie bar's and lower arms whilst still on FRK
that made it easier dropping the subby out
and i got the steering rack out whilst i was there
by then paint was dry so thought i'd carry on with the radius arms,backplates went on easy,then the hubs thing is im a lil stuck now as when going to tighten the castle nut up to 81nm it goes past the holes for the split pin,not being dumb here but i know how to set a tourque wrench and i checked in the haynes for the right tourque,when i re-assembled the hub's bearing's went in right,and made sure they were properly packed with grease and everything seems sweet just when tightened up(not even to 81nm) the hub wont turn and the castle nut gone past the hole for split pin?!??!? HELP lol
i've just left it for now and will prob search on here for a solution,then give it another try tomorrow with a fresh head
#55
Posted 04 July 2009 - 10:43 AM
#56
Posted 14 July 2009 - 12:30 AM
Seriously though, that car must have been looked after. Or painted properly at the factory.
Looking good so far, great taste in the parts department
Not relishing the prospect of fitting my f/g front end now.
I'm looking forward to finding out what sort of lump is going in up front.
Keep us posted.
#57
Posted 14 July 2009 - 12:41 AM
http://www.theminifo...x...23327&st=30
#58
Posted 14 July 2009 - 12:58 AM
I hate you. How can you possibly have a mini with so little rust
Looking good so far, great taste in the parts department![]()
Keep us posted.
i was just about to reply on your thread but now in two minds
on the way home i did contemplate calling the police,to report the previous owner had just been robbed! i only knocked him down £100 from his asking price so did'nt feel too bad
im unfortuantly self-employed and now unemployed so progress may be slower than anticipated now having to go on the "rock and roll" so im glad there's not a big panel list ahead
#59
Posted 14 July 2009 - 05:01 PM
#60
Posted 14 July 2009 - 06:29 PM
With the castle nut, you have to tighten it to the torque, then tighten it further untill the holes line up!
James
